- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
Yes, it started out as a red model. No local dealers had blue left over and I had a Apex ER that was blue so I just swapped the body work and since I was changing a-arms already I just ordered blue a-arms.
Alticity-Vector
No I was SUPPOSED to have 8s on it and ended up with 9s. (both drivers are 9s right now) So I gota get the 8s on it.
Alticity-Vector
any other info on how this sled is coming along? Does it hold rpm in the deep stuff?? things like that...
- Apr 17, 2003
- Menno, SD
- Menno, SD
First trip it would only run around 9800 rpm. Last weekend it ran flawless at 10,600 to 10,700 on long pulls and 11,000 going down the trail. I also added a 4" handlebar riser now and a left hand throttle as well.
Red2003
Do you think the mono is gonna hold up with that much track purchase againt the single spring??
- Apr 17, 2003
- Menno, SD
- Menno, SD
I had it in the shop 2 weeks ago with 400 miles on it and everything looks brand new. No signs of stress on any of the arms at all. The monoshock is holding up fine.
