sneakattak88
OK need a few ideals,, i have an turbo Attak, i have the boost figured out the fuel the clutch, lOL evrything but the skid, Its a 136 ZX2 , im dropping the front float shocks,, but have no clue about the rear, for a weekend of 2000 ft of ice drags,, any ideals on set up, oh i weight 180 lbs,,, shocks strap and pins,
kinger
- Jan 17, 2005
- Clear Lake, IA
- www.piergenius.com
In the manual I remember reading about the pin settings and for coupling they actually said to use one of the settings for drag racing only or smooth surfaces like ice, I cant remember how they worded it.
Custom Rx1
- Jan 16, 2007
I drop mine and the skid goes way up in the air. Not sure how to push it down and hold it. The pins only have a top speed setting in the book. I may strap it down but not sure if it will break.
powder muncher
Shorter shocks....
I know you can get Fox Floats in any length you want thought about doing that on mine.
Custom Rx1
- Jan 16, 2007
Can you put fox floats on the back of a ZX2? I back the springs right off. It sinks good. I have cut drag front springs. The profile angle is flat to the rail. We will see what she will do.
powder muncher said:Shorter shocks....
sneakattak88
got a pic of that? and when you say you dropped the back what did you exactly do?
Turk
Tech Advisor
Tie down the rear skid so it has about 3" travel. Use tie straps .
Custom Rx1
- Jan 16, 2007
I do not, I will have after sunday. All I did was take the old springs and cut a 2" section out And weld it back together. For the back of the ZX2 just back the springs off to the lowest setting. Get 2 people to sit on it and tie in place. It will be low. I can't wait to see if top speed goes up.
- 13K
