snowsdog
Just picked up 03 RX1 last night, only 77 miles on it.
Are there any updates or mods I should look at getting on it right away?
Any info will be helpful, new to the 4stroke family of sleds.
I read that the skid plate is a must ASAP?
rx-1 blue reverse
Str rate springs
bigger stabilizer bar
Bakemono
- Oct 5, 2004
- Edgerton, WI
- www.myspace.com
Keep an eye out for cracks on the w-arms.
Cap'n
Cap'n
jimmie d
Straight rate springs, thicker sway bar, longer links are a must.
Ripsaw track, Simmons Skis, 2" riser and seat retro make it a much better and more comfortable ride.
Lot more but those are the basics before you ride and see for yourself whay else you need/want.
Jim
Jim
Tork
Yamaha missed the front roll stiffnes calibrations by a bunch. You can ride it without the spring/bad/link mods but it is tippy. With any halfway brisk cornering the sled leans to the outside of a corner
go with what Greenmachine said, Other than that, hand warmer fix.
LazyBastard
Ah yes. My handwarmer fix.
Here's a link to the writeup by Spray25:
http://www.totallyamaha.com/snowmobiles ... warmer.htm
Note that I would set the timer to the 10sec interval rather than the minute, then you can choose what bar to start on rather than just turning them completely off.
snowy1
the best up date I found was a turbo.
sledheadgeorge
- Apr 28, 2003
- Which one? I have 6
IF YOU GET THE PIONNEER WIDE FRONT END KIT IT COMES WITH THE HEAVIER BAR AND SPRINGS, AND IT WILL CORNER LIKE ITS ON RAILS.
