Ok I have tried to no avail to find out why my engine light flickers. It does not flash it just flickers randomly. sometimes at idle sometimes at WOT and some times just cruising. Sometimes it stays on during idle then flickers when I feather the throttle and goes out when I rev it up. It does it when its cold , warm and even hot. It is so random that I never know when it will happen. Oil level is perfect and I just changed to oil and filter. Coolant level is perfect too. Anybody have any thoughts?
Check the wiring under your toolbox in the front there is a cable of wires running over the front frame. Check it out for rubbing through and shorting out. I put a rubber hose around it and zip tied it in place so it would not happen on mine. Let me know what you find!
