apracing
- Feb 19, 2013
- new brunswick
- 2004 rx1 warrior 2006 apex gt 1979 enticer 340
sled just quit ,riding along and boom ... shut off ....was told it was fuel pump ?? have spark but no vacum to one off the fuel pumps ,took to shopand was told the crank is bad ??? really ..i dont think thats the issue ...anybody have any ideas ????
was it knocking or anything?
this does not sound like a usual problem. have you checked the wiring in the nose under the tool box holder?
apracing
- Feb 19, 2013
- new brunswick
No it was running good ...
apracing
- Feb 19, 2013
- new brunswick
If one pump works than the other one should have vacuum also ??
i think the vacume pulses come from 2 different places if i remeber correctly.
can you check if there is still fuel in the float bowls? there are drains on the bottom. if it still has fuel in the carb bowls, it is a eletrical/spark problem and i am not always the greatest on those.
smokingcrater
maim said:i think the vacume pulses come from 2 different places if i remeber correctly.
Correct, vacuum pulls of 2 different carbs and they aren't connected on the vacuum side. A bad cylinder will cause no vacuum impulses.
Anyway, check spark first, and then compression test while the plugs are out.
Buckeye
- Lakes Region, NH
What does it do when you try to start it?
apracing
- Feb 19, 2013
- new brunswick
Found issue .. Took valve cover off and found pieces , so not good , need cams and head ..
RxThunder
How many miles were on that sled?
apracing
- Feb 19, 2013
- new brunswick
12 miles , totalled the top end , bought a used drop in
RxThunder
apracing said:12 miles , totalled the top end , bought a used drop in
12,000?
