apracing
- Feb 19, 2013
- new brunswick
- 2004 rx1 warrior 2006 apex gt 1979 enticer 340
i was riding along ,no issues ,then my rx1 started to miss really bad ,back fire like crazy ,flames out the rear ....rpm gauge going crazy ,let off throttle and rans fine ....tried to give throttle and wont hardley pull it self ??? ...it was running like a champ all winter ??? any ideas ??
Sucking air... exhaust donuts or cracked mid pipe or flex pipe. Also it possible you fouled a plug too... or maybe sucked some bad fuel or water from fuel.
straycat03rx1
- Aug 6, 2014
- t cats out the a$$ one rx1
Check your throttel cable and make sure its in the throttle block right. sounds like the safety switch.
You mean it could be TORS...
straycat03rx1
- Aug 6, 2014
yup. make sure the cable is routed right. If you did the 2" riser it has to be just right. It acts like what you are saying.
- 15K
