snow1
I got a 2005 rage with 600 miles on it for my wife in June and it's our first Yamaha (former cat owners). I get a snapping noise from the front of the rear skid when going over small sharp bumps (low speed). On large long bumps its ok, I adjusted suspension to spec, no change. I then tried adjusting front and rear shocks, transfer rods and spring angle, not much change. Sounds as if front skid shock has very little rebound damping (not transfer rod noise). Is there a fix for this? Did any one try different shocks or springs on front of rear skid? What would happen if i took almost all tension off this spring/shock?
