Ok I tried a search and must not be doing it right as i Got 123 pages of stuff
I know this has been talked about before but here goes.
2005 Vector just put in a Ohlins 36PCW shock Compression adjustable only. What is the best set up for this?? It rides harsh. Bottoming is NOT the problem. I can bottom it if trying to but typically this is ok. The problem is the smaller bumps feels like it doesn't move.
According to those ridding with me the front arm moves up and down it appears like the rear does not travel much
I tried changing the springs from Medium to hard this was surprisingly better
Right now the transfer rods are set to about full coupled this seems better than fully uncoupled as the sled stays flatter and more in controll but didn't make it softer.
Could somebody give me some tips on correct set up of the suspension with this shock?
I'm lookng for a smooth ride at medium speeds in medium trail chatter,maybe all i need to do is soften the compression damping?
