Gerry
- Apr 6, 2007
My 2005 RX1 has the two tabs that hold the airbox secure to the frame and carbs which in turn holds the carb boots on to the airbox. Over the years the two tabs secure to the frame of the sled have worn out and no longer keep the airbox tight against the carbs and the frame. This causes the boots to come off the carbs and I'm afraid the motor will run lean and cause more issues. Yamaha no longer makes the lower airbox so I need to fix these two tabs. Any suggestions would really help!
