2005 RX1 popping/backfiring........
Thanks for the reply....... What did you guys do to resolve the issue? Carbs or cable sticking?
We Just back off the throttle for a bit then we hammer back on it.
I have heard about unpluging it, but I am u sure of where the plug is.
Hopefully. Now I'll be a little concerned at first when I go for a run, of course. Just tested TORS per the manual and it worked properly. Wouldn't rev above 3k.....
When it happened, the sled backed right down and came to halt. Let it idle for a little bit, then I could take off again. My primary engages at 5k.... Unlike the stock 330o, I believe.....
How can you stand that?
Well, it's clutched, piped, jetted, it's just the way it's set up. I'm used to higher rpm engagement. My '96 Polaris Ultra I had before the RX engaged at least 5k............ :)
Bet that must be quite a ride having it kick in at 5k! My old Arctic cat was that high also, made for a fun trail sled but don't ever stop in deep snow.
Hey Smoke...... It boogies....... Just don't care for the clunk at times.......
It CAN be changed without removing the pipe. :)
Call me if you want
I am sure you are on the right track.
