Zomboskid
- Oct 6, 2016
- Waukesha Wisconsin
- 18 Sidewinder BTX
86 SRV 540
We Just back off the throttle for a bit then we hammer back on it.Thanks for the reply....... What did you guys do to resolve the issue? Carbs or cable sticking?
I have heard about unpluging it, but I am u sure of where the plug is.
Hopefully. Now I'll be a little concerned at first when I go for a run, of course. Just tested TORS per the manual and it worked properly. Wouldn't rev above 3k.....
When it happened, the sled backed right down and came to halt. Let it idle for a little bit, then I could take off again. My primary engages at 5k.... Unlike the stock 330o, I believe.....
4strokeluvr111
- Aug 27, 2011
- NW Wisc.
24K miles
How can you stand that?
Not sure what you mean, the 5k clutch engagement?
Well, it's clutched, piped, jetted, it's just the way it's set up. I'm used to higher rpm engagement. My '96 Polaris Ultra I had before the RX engaged at least 5k............
smokingcrater
Well, it's clutched, piped, jetted, it's just the way it's set up. I'm used to higher rpm engagement. My '96 Polaris Ultra I had before the RX engaged at least 5k............![]()
Bet that must be quite a ride having it kick in at 5k! My old Arctic cat was that high also, made for a fun trail sled but don't ever stop in deep snow.
Hey Smoke...... It boogies....... Just don't care for the clunk at times.......
4strokeluvr111
- Aug 27, 2011
- NW Wisc.
24K miles
It CAN be changed without removing the pipe.
It CAN be changed without removing the pipe.![]()
What can be changed?
4strokeluvr111
- Aug 27, 2011
- NW Wisc.
24K miles
Your engagement RPM
Your engagement RPM
Isn't that with the primary spring? I don't think either clutches have stock springs..... I keep forgetting who I'm talking too....Lol
4strokeluvr111
- Aug 27, 2011
- NW Wisc.
24K miles
Call me if you want
polarisconvert
- Mar 22, 2006
- Corunna, MI
- 2005 Yamaha RX1
Ted Jennety Clutching, jetting, air box mod.
Arctic Cat Z1 Turbo 128" Rear Suspension
128" Hacksaw 1" track.
Heated seat
I am sure you are on the right track.
- 6K
