Brian W
- Feb 1, 2011
I have a 2005 Vector and this weekend had an intermittant electrical problem with one cylinder not firing. Changed the spark plug but did not seem to make a difference. Could this be a problem with the ignition coil assembly for the cylinder. Cylinder on the far right not firing.
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
First thing I'd do is swap coils around. Take the coil from the cylinder you suspect isn't firing and switch it out with a cylinder that is firing. If the problem moves then you know its a coil.
If you find it is a faulty coil I have a bunch available.
Wrap the coils with electrical tape. This will prevent them from cracking or failing.
05candyredrx1
#3 not firing
I have the same problem with #3 not firing occasionally. I swapped coils and replaced the plug. Problem still remains with #3. Pulled the carbs for the 3rd time & cleaned. Could not find an issue. Any ideas?
snowslammer
i have same problem with venture what the heck
05candyredrx1
Found the problem -. resolved
The problem was flooding during rapid deacceleration. This was caused by the float being out of spec.and needed adjustment. Check the float heights - 16mm for mine with the carb inverted, main jet pointing to 2the o'clock. Works awesome now...too bad the snow melted Monday.
