RSVECTORFREAK
- Oct 28, 2004
- Chassell Michigan
- 2005 RS Vector ER
Are the coolers getting warm at all?
If you idle sled with cap off are there air bubbles coming out?
You may have an air lock now, but the source of your original overheat problem when it first happened would not have been an air lock because you never introduced air into the system on your previous 70 mile ride. The only way I see an airlock happening is a head gasket leak that injects air into the coolant system and disrupts flow.
The other option could just be a faulty temp sensor. Sensor may be providing a bad reading to ECU. Coolers may not feel that hot because it really isn't that hot.
Still Fighting this problem as the sled sat for 2 years. Drained coolant, refilled, bleed system multiple times and got coolant flowing in all heat exchangers as all heated up in the 3 to 5 mins per manual. Ran sled 400 feet overheated. (we tried this 6x) New thermostat, pulled most coolant lines when drained didn't see any blockages. Didn' pull the lines in front of exchangers yet. Repeated bleed procedure like 6 times. Stumped. Tryng a pressure tester next for leaks.
4strokeluvr111
- Aug 27, 2011
- NW Wisc.
24K miles
Sounds like your water pump is toast.
RSVECTORFREAK
- Oct 28, 2004
- Chassell Michigan
- 2005 RS Vector ER
It's beginning to look that way. Going to dealer tomorrow. I'd just be changing parts from here on out otherwise. Sure acts like trapped air though.Sounds like your water pump is toast.
grizztracks
TY Advertiser
- Feb 24, 2005
- Scio, NY
I've never had any problem bleeding these cooling systems. I fill the system then run the engine long enough to open the thermostat. With it running top off the coolant until it stops taking it then cap it and let it cool. After it cools top off coolant then run it through another heat cycle and keep adding coolant after it cools until it no longer takes it. Usually 2-3 heat cycles will bleed all the air out.
If it's pushing coolant out the overflow it may have a blown head gasket. I've done several head gaskets on these engines over the years but have not yet ran into a coolant pump failure.
RSVECTORFREAK
- Oct 28, 2004
- Chassell Michigan
- 2005 RS Vector ER
Ouch! It held pressure at 14lbs when we tested the system. I thought a head gasket would show a drop.I've never had any problem bleeding these cooling systems. I fill the system then run the engine long enough to open the thermostat. With it running top off the coolant until it stops taking it then cap it and let it cool. After it cools top off coolant then run it through another heat cycle and keep adding coolant after it cools until it no longer takes it. Usually 2-3 heat cycles will bleed all the air out.
grizztracks
TY Advertiser
- Feb 24, 2005
- Scio, NY
Engine compression along with heat expansion will find it's way into the cooling ports if the head gasket is bad and/or head is warped. The engine compression is up around 200 psi which is well above the maximum running pressure of the cooling system.
RSVECTORFREAK
- Oct 28, 2004
- Chassell Michigan
- 2005 RS Vector ER
And it will still run good and idle with a bad gasket or warped head??
Sent from my SAMSUNG-SM-G930A using Tapatalk
grizztracks
TY Advertiser
- Feb 24, 2005
- Scio, NY
Yep, not enough compression lost to make a noticeable difference in how the engine runs. All the head gasket jobs I've done so far ran great. They just couldn't be ran down the trails without pushing coolant out and overheating.
RSVECTORFREAK
- Oct 28, 2004
- Chassell Michigan
- 2005 RS Vector ER
Yeah this one wouldn't go past 400 feet and it's hot already.Yep, not enough compression lost to make a noticeable difference in how the engine runs. All the head gasket jobs I've done so far ran great. They just couldn't be ran down the trails without pushing coolant out and overheating.
RSVECTORFREAK
- Oct 28, 2004
- Chassell Michigan
- 2005 RS Vector ER
Dealer said motor has internal damage because the shaft that spins the water pump isn't turning(balancer shaft) and they are broken pieces in water pump.
grizztracks
TY Advertiser
- Feb 24, 2005
- Scio, NY
The pump drives off of the counter shaft so if the counter shaft isn't turning I'd think you'd have a vibration. Pump drive gears bad because the pump came apart and locked up?
RSVECTORFREAK
- Oct 28, 2004
- Chassell Michigan
- 2005 RS Vector ER
Man I wish I knew what to do at this point Grizz. Dealer said too much $$ not worth fixing. Do I buy a used motor probably not worth it at the cost then the labor to install. UghThe pump drives off of the counter shaft so if the counter shaft isn't turning I'd think you'd have a vibration. Pump drive gears bad because the pump came apart and locked up?
DGZRT
- Feb 23, 2006
- Stevens Point Wisconsin
Sorry for the bad news ! Lots of Apex's and Vectors out there. Part it out and find another. How many miles were on it ?Man I wish I knew what to do at this point Grizz. Dealer said too much $$ not worth fixing. Do I buy a used motor probably not worth it at the cost then the labor to install. Ugh
RSVECTORFREAK
- Oct 28, 2004
- Chassell Michigan
- 2005 RS Vector ER
9641 I'm having it fixed. Too much into it to let go now.Sorry for the bad news ! Lots of Apex's and Vectors out there. Part it out and find another. How many miles were on it ?
I sent you a message, look in your in box
