Zack
- Sep 28, 2014
- 2005 Yamaha rs vector
hey guys i have been looking all over the internet trying to find a manual for my sled (2005 rs vector) with no luck. I just bought the sled knowing it was going to need a stator but I did not know how impossibly hard it was going to be, I am no novice mechanic but I cant see any possible way to get the engine out as the cases on both sides of the frame hang over about an inch any help would be greatly appreciated
thanks
thanks
If you become a VIP then you can get the downloadable manual.
J1635
Suspended
- Aug 17, 2014
- Yamaha Nytro
vip will help you out.
as much as you would like to get this job done without having to remove the engine, the truth is it will be 1000 times easier if you do. once you drain the fluids, disconnect the electrical harness (easy) and then remove the top aluminum frame body. after that its peanuts to pull the engine, check your chain tensioner and exhaust gaskets while you have it out
Zack
- Sep 28, 2014
Alright so I went ahead and figured out how to do it without the manual. to replace the stator on an 05 rs vector you have to take off the oil tank, steering bar, exuast, moter mounts, secondary cluch( have to take this off to get out one of the moter mounts), airbox/ battery, upper frame support, seat/ gas tank(to get to exuast), both side plastic peices, as well the handle bars and all of the connections and cables on the bars I would also recommend removing the hood so that you can use a car engine hoist to get it out if you are just replacing the stator you can just remove the things above, if you dare removing the engine you will just have to remove the coolant hoses and its out if you have any questions feel free to ask, this is quite a bit of work so if your unsure if you can handle it I would recomend taking your sled to a dealer
J1635
Suspended
- Aug 17, 2014
- Yamaha Nytro
did you change chaincase tensioner and exhaust donuts?
Zack
- Sep 28, 2014
Chaincase tensioner?
J1635
Suspended
- Aug 17, 2014
- Yamaha Nytro
lol ah jeeeeez
he means timing chain tensioner if it has not already been done.
J1635
Suspended
- Aug 17, 2014
- Yamaha Nytro
yeah, to be more specific
http://www.ty4stroke.com/threads/cam-chain-tensioner-replacement-3-cylinder-engine-05-07.90826/
is very important if it hasnt been done, catastrophic engine failure if it goes. and since you have to have everything apart to do it, its a good time to change the donuts in the exhaust manifold
sucks if you do it you have to take the engine out again, but it should be super easy the 2nd time
http://www.ty4stroke.com/threads/exhaust-donut-replacement-procedure.90978/
Zack
- Sep 28, 2014
I didn't replace the tensioner, I will keep a close eye on it tho, I looked at my exaust doughnuts and they were fine, the sled only has 2500 miles
TheMAZ
- Nov 27, 2014
- Upsate, New York
- 2005 Yamaha RX Warrior, Apex Seat Upgrade, FOX Shocks, 1.5 Ripsaw Picked
2005 Yamaha RS Vector- Bone Stock
Where do I get the manual?If you become a VIP then you can get the downloadable manual.
Biscorascal
- Jan 8, 2015
- Dowling
- Yamaha rs venture
How do you become a VIP ? I need a manual to replace stator on my 05 rs venture
Pretty easy... see the "VIP" in the menu bar above??? Click on that.
Biscorascal
- Jan 8, 2015
- Dowling
- Yamaha rs venture
YamahaHoss
- Mar 23, 2020
- Wisconsin
- Yamaha RS Venture
Zak... I am attempting to do this on my 2006 RS Venture. Could I ask you a few questions please..Alright so I went ahead and figured out how to do it without the manual. to replace the stator on an 05 rs vector you have to take off the oil tank, steering bar, exuast, moter mounts, secondary cluch( have to take this off to get out one of the moter mounts), airbox/ battery, upper frame support, seat/ gas tank(to get to exuast), both side plastic peices, as well the handle bars and all of the connections and cables on the bars I would also recommend removing the hood so that you can use a car engine hoist to get it out if you are just replacing the stator you can just remove the things above, if you dare removing the engine you will just have to remove the coolant hoses and its out if you have any questions feel free to ask, this is quite a bit of work so if your unsure if you can handle it I would recomend taking your sled to a dealer
