2006 RS Rage leaking chaincase oil....
I beleive some of the 06 sleds had problems with the chaincase covers. There is a updated cover now ,if gasket and everything else checks out. plowking
Make sure it is the chaincase. A few cracked engine oil tanks are showing up now that these models have a some miles on them. Mine was just replaced at 4200 mi. It leaked out under the same area as the chaincase.
just pull the right side panel off and let it sit in the garage over night..u will have a small puddle and know exactly where its comin from...if its a crack in the oil tank you will never be able to find it unless u take it off...or its right out in the front where uc an see it
