Yamaha4life1990
- Dec 24, 2019
- 2007 yamaha apex
Hey guys. Installed a hauk exhaust, air box mod, power commander 3 and a wideband afr gauge. Installed everything runs absolutely awesome and snappy as hell. Problem is my idle is at 1500 rpm and wont go lower
I played with the adjusting knob on the left side of the throttle bodies but doesn't change anything.
Any advice ?? Thank you
What is the AFR gage saying at idle?
Yamaha4life1990
- Dec 24, 2019
- 2007 yamaha apex
Aft is reading between 12.0 and 12.5 at idleWhat is the AFR gage saying at idle?
I thought you might be lean at idle but your AFRs are good. You may need to calibrate your TPS to sync up with your PC3 I know it was a necessary step when installing a PC5.
Macheater
- Feb 7, 2006
- Niles, Ohio
- 2006 Apex GT, 2002 SRX700, 2023 Polaris Boost VR-129
- Niles, Oh
Sounds like the IAC is stuck or defective.
Yamaha4life1990
- Dec 24, 2019
- 2007 yamaha apex
Figured it out, the previous owner had that mixture screw cranked way in, got it idling at 1400 now which from what I've read is perfect.I thought you might be lean at idle but your AFRs are good. You may need to calibrate your TPS to sync up with your PC3 I know it was a necessary step when installing a PC5.
What mixture screw is that?Figured it out, the previous owner had that mixture screw cranked way in, got it idling at 1400 now which from what I've read is perfect.
Yamaha4life1990
- Dec 24, 2019
- 2007 yamaha apex
Sorry not the mixture screw. The idle screw on the theft side of the throttle body pack. The one with the black knurled end on it.What mixture screw is that?
Macheater
- Feb 7, 2006
- Niles, Ohio
- Niles, Oh
Isn't that what you said didn't have any effect in your first post???Sorry not the mixture screw. The idle screw on the theft side of the throttle body pack. The one with the black knurled end on it.
Yamaha4life1990
- Dec 24, 2019
- 2007 yamaha apex
Yes, I didnt realize the guy had it wound all the way in so i only backed it off maybe 3/4 a turn and nothing happend so I thought maybe a I had a different problem. But when I turned it back a bit more my idle finally dropped. I figured it would be really sensitive moving that screw and thought 1/2 turn or so would show a difference hence the post. Thanks everyoneIsn't that what you said didn't have any effect in your first post???
- 157K
