Dealerjohn
- Mar 26, 2010
- Labrador
- 2015 MTX Viper, XTX Viper, 2001 SRX 700
Hey guys,
I have a 2007 Attak and I ride very aggressively, not much jumping but very fast no matter how bumpy it gets.
For a little while now I have noticed coolant dropping from the running board cooler. I have taken them off several times now, and there is a usually a crack on the back side of the 90. I am thinking this is caused by running board flex in the big bumps and it is causing the coolers to flex and crack.
It happened again a couple days ago, I have since brought them to an aluminum welder to have them fixed up.. However I feel this is again only going to be a temporary fix... I am going to order the tunnel reinforcements from the 2011 Apex and I think that may help.
My question is if anyone has ever heard of this problem and know of a permanent fix?
I'm really hoping this weld job and the tunnel reinforcements will do the trick but any other help would be appreciated.
Thanks!!!
Thanks!!!
SnowBandit
- Jan 31, 2004
- Maine
- www.slednewengland.com
- 2009 Nytro xtx
Had the same problem. I JB welded mine and its holding. What I did was stick some foam tape between the suspension mount and the cooler. Seems to have given it some padding. Got over 4,000 miles and no leaks...
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
fyi if you do weld ....remove the ecu to prevent a catastrophic shortout
Dealerjohn
- Mar 26, 2010
- Labrador
We took the coolers off and brought them to the welder... He welded and it leaked... we brought it back to him... he welded and it leaked.. I put some JB Weld on it and some water weld... It has a very slow weeping leak now. Nothing is dripping, yet.
Thats a good idea with the foam. I will try that.
