scott32
- Jan 12, 2009
- huron county, ontario
- 07 Apex RTX se, 09 Nytro XTX
Right on, ride on!!
Jonesynl
- Nov 6, 2014
- Roberts Arm, Newfoundland, Canada
- 2008 Apex MTX SE
Hopefully it works good lol
Lonerider
- Feb 26, 2010
- south west mi
- 04 rx1, 05 Warrior 06 Attak-w/yamacharger, 07 Attak-Supercharged, 17 Sidewinder TD power trail
Q1- Is it going to have a air lock? anti freeze movement---- engine to back of sled, ( hi spot, air bubble ) to front of tunnel, ( lo spot, will fill solid with anti freeze ) then cross pipe, to back of sled (hi spot, air bubble ) then to engine, ( lo spot ) will the t stat work? something to think about, maybe a bleed screw on each side? I would skip the factory running boards in the tunnel & add 1 or 2 rear heat exchangers & run through the new homemade running boards. Maybe a 2nd radiator & fan Build it, Enjoy , let us know,
Jonesynl
- Nov 6, 2014
- 2008 Apex MTX SE
I totally understand what your saying now, but is it any different then a double U pass cooler? And thinking of it the way your saying, I can't see it really working. I rear cooler or two would be great, will have to consider doing that and do you know nu any chance where to find a good price on one?
Sasquatch
- Apr 17, 2004
- North Western Ontario
- www.dptc.com
- Yamaha's
I have no idea what my temp my apex runs at now but I would think she will run a lot cooler with the coilers in the tunnel.
Exchangers in the tunnel I think are a good idea but why run them in the boards? I don't think you need them for cooling with the exchangers in the tunnel.
Jonesynl
- Nov 6, 2014
- 2008 Apex MTX SE
I'm removing the factory running board coolers, putting in a tunnel cooler or even two, but I have to run my coolant through my running
boards for the plumbing, like fabcraft design.
Lonerider
- Feb 26, 2010
- south west mi
Classifieds, Travis @ barn of parts, or Laneo,
