CWAB
- Jan 26, 2015
- 2008 Yamaha Nytro RTX 40th Anniversary
Hey Everyone, new to the site. I have an 08 Nytro that has a code 12. The engine turns over but does not fire. I have checked the resistance in the crankshaft position sensor and it is within spec. Any help would be greatly appreciated! Thanks
CWAB
- Jan 26, 2015
Sorry, forgot to mention that my battery did go bad and I have with replaced it with one out of my RX1. Thanks again
yamahamm
- Oct 9, 2009
- Norway, Salangen, Troms
- Norway
- 2008 yamaha nytro mtx mcx 270
Change the crank sensor. It is most likely broken. It can show right when measured but still be broken, was like that on my nytro.
CWAB
- Jan 26, 2015
Thanks for the response, I actually found that I didnt have continuity through that black/blue stripe wire, traced it back to a group of black/blue stripe wires that were kind of green in the connector. Cleaned them up and got continuity through to the ecu. It started and ran so hopefully the issue is fixed!
