burlyviper
- Apr 30, 2012
- Ottawa Lake MI
- 2018 Sidewinder LTX LE, blue
2011 Apex 128, Ulmer Airbox and clutch kit, PCV, HID
1980 Exciter 300
I just purchased a 2008 Phazer RTX. It has fox floats on the front and rear. I've never had either a phazer or fox floats. Any suggestions on setting up the suspension for my 130 lb daughter? How much PSI to run in the front; rear and where should the limiter strap be set? We will be riding mostly trails and open fields.
Thanks.
Thanks.
- Nov 1, 2009
- Winnipeg, Manitoba
- 2009 Phazer RTX
You can probably start off around 45 or 50psi in the front. Rear springs probably on M or S (basically to hold the sled up with the rider on it) and then adjust the shock as needed to absorb bumps. The tighter the strap the heavier the front end will feel, steering will feel heavier as well, however I feel I have better control when its a bit tighter. Best to have her try it out and see where its at in my opinion.
donkickit
- Sep 23, 2007
- Upstate New York near Albany
- 2014 viper ltx se
My son runs the back at SOFT and the fronts on 50. Works well.
Also has 96 studs and dual carbides for better control than stock.
Gone Blue
- Oct 11, 2006
- Howell, Michigan
I too am running 50 PSI on the front Floats and using Stud Boy 6" Dually's. My sled handles awesome with this set up. G.B.My son runs the back at SOFT and the fronts on 50. Works well.
blueironranger
- Feb 3, 2009
- Iron Range MN
- 2014 Viper XTX
2009 Phazer MTX
There are also other spring combos available if you can't lighten it enough, the RTX has the stiffest springs stock, GT softer, and MTX softest. The RTX rear clicker shock is notoriously stiff shock from the factory and could really use a revalve for a 130# rider.
burlyviper
- Apr 30, 2012
- Ottawa Lake MI
1980 Exciter 300
I have fox floats on front and rear. Do I make this adjustment with the sled in air (no weight on skis)?
ATV PRO #11
- Jan 22, 2011
- Garson, MB, CANADA
- 2014 Yamaha Phazer XTX
Yes. No weight on shock to get accurate psi.I have fox floats on front and rear. Do I make this adjustment with the sled in air (no weight on skis)?
blueironranger
- Feb 3, 2009
- Iron Range MN
- 2014 Viper XTX
2009 Phazer MTX
Floats in both spots I the rear? Sounds like the Timbersled suspension kit. If so I'd probably start at 50 center and 110 rear. I replaced my center with a float and run ~60psi on that one, I'm right at 190# with all my gear on. Rear would be torsion springs if it's stock and a float won't work there.
