2009 Apex what should I look at before purchasing
check your battery and check to see if you have the updated starter relay (red solid state), down by your left foot well. Not sure exactly which one it is but there are 4 or 5 (not at home to check) that look the same if non are red then i'd update it otherwise it might freeze and keep you from being able to start it on a cold morning.
sounds like you've got everything pretty well covered. should be worry free for quit a few miles now. ;)!:sled1:
I will check that out tonight, thanks
As a VIP member now how can I go about down loading a copy of the owners manual and were do I need to go to find this?
