rkkoeb
- Aug 30, 2019
- Green Bay
- None right now
is this the soft start primary clutch spring people are using in the Apex? Is it truly a good upgrade to do?
https://www.barnofparts.com/apps/webstore/products/show/7079922
Is the stock secondary clutch spring the pink one?
Here is a the link to the TY Tech area. Once you select the correct year you can see the stock specs and settingsis this the soft start primary clutch spring people are using in the Apex? Is it truly a good upgrade to do?
https://totallyamaha.com/snowmobiles/AAATuning Chart/Specs.htm
Soft start is good for people that do not like an aggressive clutch engagement
You ask a Mod.ok I am now a VIP member were do I go to down load the manual
Check your PM
slowride06er
- Feb 15, 2014
- Ford River MI
- Apex
If you are going with tall windshield I'd recommend the one with supports. If you're replacing the snow flap I'd go with the newest style found on 2011s on up they look better in my opinion. Not sure your going to find alot of information on led lighting on apex that said Id go with Rocks hids literally night and day difference. Lots of knowledgeable and helpful people on this site welcome and enjoy your new ride.
Teamblue4
- Feb 20, 2008
- Il.
- 2012 Apex XTX
2013 Apex SE
2014 Apex SE
2014 Apex XTX
2016 Apex XTX
Stock spring is pink, I run a soft start spring from Schmidts Bros Racing for a lower engaging RPM.is this the soft start primary clutch spring people are using in the Apex? Is it truly a good upgrade to do?
rkkoeb
- Aug 30, 2019
- Green Bay
- None right now
So I have the sled all taken apart now and found one of the exhaust flanges broken off on the Y pipe. Has anyone tried TIG welding this back together with any good results? If not were is a good place to purchased a used or new Y Pipe?
- Jun 28, 2004
- Clinton, Wi.
Port Yamaha is your go to place for parts. Long time advertiser and huge site sponsor/supporter. Let them know you're a VIP member!
Teamblue4
- Feb 20, 2008
- Il.
- 2012 Apex XTX
2013 Apex SE
2014 Apex SE
2014 Apex XTX
2016 Apex XTX
henseljg2 is a member here He might have a used one.
rkkoeb
- Aug 30, 2019
- Green Bay
- None right now
Anyone have the part number for the tall windshield and a good place to purchase it from
theCATman
- Feb 19, 2007
- WI
- Yamaha
Good luck finding a new one in the USA.
Check Yamaha Canada. Supposedly they still have some NOS ones on hand, but don't hold me to that 100%.
You may wind up settling on a used one from Barn of Parts or Spa City Sled Parts.
And for $2300, you stole that thing. I gave $3200 last February (2019) for my '09 LTX-GT with 4,740 miles and thought I bought it right, and it too needed a couple minor fixes (donuts, bulkhead/arm bushings and one A arm, it was slightly tweaked)
rkkoeb
- Aug 30, 2019
- Green Bay
- None right now
so trying to get the Y pipe disconnected from the can portion of the exhaust and not having any luck. I have the clamps removed and it just doesn't want to separate. Any recommendations
Method 1. Keep the Y pipes bolts in and tight. Get a 16" long block of wood. Place that on the front side of the muffler. Grab your heaviest hammer and proceed to bang off the exhaust. Have had to do this numerous times to mine.
Method 2. Drop the skid. Heat both ends of the exhaust pipe un 'til cherry red and then pull or tap the muffler back.
Either method you do you will probably need two new exhaust gaskets.
rkkoeb
- Aug 30, 2019
- Green Bay
- None right now
Just wanted to give everyone an update of what has been done now
- Engine oil and filter changed
- Chain case oil changed
- Antifreeze flushed
- New spark plugs
- Jackshaft bearing repacked with grease
- Speedo bearing repacked with grease
- Primary and Secondary clutches cleaned
- New secondary spring order
- New soft start primary spring order
- New exhaust donuts
- Purchase used Y pipe for section that has flanges broken off
- New high windshield purchased
- New slides
- New bearings for bogie wheels
- Replaced rear bogie wheel shaft with used unit as bearing was spun on shaft and damaged the shaft
- Replace broken piece of plastic around head light
- replace missing mud flap
- Grease complete sled
- New spark plugs
- New slides
theCATman
- Feb 19, 2007
- WI
- Yamaha
- New spark plugs
- New slides
Where did you find a tall windshield??
