wkeggenhoff
- Dec 20, 2007
- Ajax,Onatrio, Canada
- 2006 Yamaha Apex RTX
Anyone change their starter ? Looked at small cover underneath belly pan see filter but no starter
Where is it even located ? Front of motor, rear ?
Parts breakdown doesnt show where mounted
Getting power out of start solinoid wire that goes to starter but it doesnt make anykind of noise at all
thanks
thanks
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
Its on backside of the motor above oil filter. No easy way to get at it
DGZRT
- Feb 23, 2006
- Stevens Point Wisconsin
The first thing I would do is check your starter relay. Its down by the Battery .
This is of the Apex but almost the same procedure. When you get down to the Battery look at the Small relay Block on the Left hand side of the battery. Clean these up very well. If there full of Green corrosion maybe get a new Starter relay.
Don't , put everything back together until you try it . You can plug the wires in by the head light and try to start it . If everything is perfect with the relay block then leave everything apart and we will go on to the next step .
DGZRT
- Feb 23, 2006
RobX-1
- Coldwater, OH
Using the video DGZRT provided, here's a still image shot where I circle the relay (small circle) and the starter (larger circle). Like Travis mentions, there's no easy way to get at it but if you've ever done an oil change, most if not all of the parts that need to come off to replace starter would have been removed.
I've done this a few times, the front motor mount bolts have to come out and undo the exhaust flanges also. The rear motor mount bolt needs loosened, and the motor then will pivot enough to get it out.
vector/venture starter is on the rear of the motor. supposedly tipping the engine ahead and pulling the filter helps.
TinMule
- Feb 23, 2020
- West Nipissing, ON
- 09 Venture RS
07 Venture Lite
Not an easy job but doable. Have a look at this thread:Anyone change their starter ? Looked at small cover underneath belly pan see filter but no starter
thanks
2005 RS Rage - Starter Replacement
Hello All, Wanted to share, as your posts and pictures have been immensely helpful. Here's the situation: - End of season ride, shut down the machine on the trail, wouldn't do anything to start, grabbed jumper cables, no luck, towed home - Using multi-meter, confirmed voltage coming...
ty4stroke.com
- 16K
