I got my new nytro from the dealer and the same day it went down to powderlites for a turbo, yeee haaa!! After I got home I took apart my secondary to see all the settings on the spring and the shock wave helix. (never had one so wanted to know how it worked) At this point I found that the inner sheive has lots of deflection on the clutch shaft. The inner bushing has lots of play. It looks bad enough that even the belt ride hight is not even around the clutch in the belt contact area, 1.5mm top and bottom and just below sheive hight toward the back. Is this normal for a sled with 00000km?
Tarzan
- Oct 28, 2009
- Norway
- www.youtube.com
- Norway
I dont think so
