2011 Apex is here!
What RPM did you clutch it to. Spec in the manual is 10.000-10.750. Engagement 3.200-3.600. Mine is 3.200.
Larry
Larry
10,400-10,500 seems to be the sweet spot with a stock intake and exhaust.
Alatalo said:
Compared to the old engine, how much more helix / weight does it pull...?
Not trying to figure out the spec of your clutch kit, just asking to get a reference compared to the old engine.
It has more low/mid grunt to harness than the old engine. Comparing the clutching to an old Apex isn't a 100% equal comparison because you are comparing a 121 (old short track) to a 128 (new short track) and a 136 (old long track) to a 144 (new long track).
Come check out the 2011 Apex XTX that we'll have on display at Hay Days!
My 2011 APEX SE IS HERE!!!!!!!!
Picking it up Saturday
Hopefully it is better then my old 05 RX1ER!!
Srxspec said:
Larry
Are you able to share the stock pre 11' apex track hp curve to the 11' stock apex power curv and post it up?
This is of a 2007 Attak vs a 2011 Apex XTX (136 vs 144). The 2011 has quite a bit more all the way through.
Red = 2011 Apex XTX
Blue = 2007 Attak
It's catching up with the SRX 700, but just barely :)
Black 2011 Apex SE on the dyno now! Will try to post some pictures soon!
NYRider - welcome to the site, would you please fill in your location in your user profile, it's a site requirement.
rxrider
TY Management Team
Allen - I'm looking forward to the #s - thanks for taking your time making the dyno runs :)
2011 Apex Clutching & MOD Air Box graphs showed below!
2011 Apex SE Stock vs Ulmer Racing Clutch Kit
2011 Apex SE Stock vs Ulmer Racing Clutch Kit & MOD Air Box
