attak 06
- Jan 12, 2009
- Deer Lake, NL
- 2011 Apex XTX
Is the PC V available for a 2006 Attak with a yamacharger? If so, what gains are there, and what would be the price with the mapping for the yamacharger? Thanks!!
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
Yes I have PC V's available for the 2006-2010 model Apex with a Yamcharger. You will notice better acceleration and slightly better top end when added to the Yamcharger. Pricing is $360.
- Apr 17, 2003
- Menno, SD
- Menno, SD
TTT
kinger
- Jan 17, 2005
- Clear Lake, IA
- www.piergenius.com
Hey allen think you could map a PCV and auto tune for my sled?
I want to run my sled start and it wont work with the GEMS, oh yeah and the fact the PCV is better then the GEMS LOL
FLYBYU
Hey Kinger, Sled Start will work with gems. But you have to change wiring. When I designed it I told Curt about it. It has to go on the stock side of the plugs of the injectors. It's trying to read the stock frequency pulses from oem ecu. It has a window that it will accept or it thinks it's over reving and shuts down. Gems alter that frequency pulse by either taking fuel which lowers the pulse or add fuel which increases the pulses. Any questions let me know.
KevinS
kinger said:Hey allen think you could map a PCV and auto tune for my sled?
How old is your sledstart? I had one of the earlier sledstart modules and I was not able to get it working with a PCV. I ended up selling the PCV. Kurt may have some new modules that allow sledstart to work with a PCV.
FLYBYU
KevinS did you try how i just explained it Kinger?
kinger
- Jan 17, 2005
- Clear Lake, IA
FLYBYU said:Hey Kinger, Sled Start will work with gems. But you have to change wiring. When I designed it I told Curt about it. It has to go on the stock side of the plugs of the injectors. It's trying to read the stock frequency pulses from oem ecu. It has a window that it will accept or it thinks it's over reving and shuts down. Gems alter that frequency pulse by either taking fuel which lowers the pulse or add fuel which increases the pulses. Any questions let me know.
The GEMS doesn't plug into the injectors at the injectors its just a big adz plug on the clutch side of the engine. Your saying cut the plugs on the sledstart and solder them in to the big wire harness before the GEMS?
I have one of the first sled starts after it was plug and play, and yes same issue it doesn't know its running and shuts down
FLYBYU
If the gems doesn't plug into the injectors it won't work because its altering the signal before the oem connectors. Like the dobec boxes and the rb3 that plugs into injectors plugs .
machzrobbie
Any idea when the ignition moduel for the PC5 will be ready
