sideswipe77
- Nov 7, 2014
- Michigan
- 2012 Yamaha apex se
2011 Yamaha apex se
Anyone know the color for the clutch spring to lower rpm engagement.
sgauthier
- Mar 5, 2009
- southwest, Ontario
- 2011 Apex XTX
Barn of Parts or Schmidt bros racing has them
02ViperMody44
- Jan 26, 2009
- Utica, NY
2013 Yamaha XTX
- Old Forge, NY
- YAHOO
- ramody44@yahoo.com
Schmidt bros has a nice set-up. Noticeable difference on my '13XTX compared to my '11SE.
sideswipe77
- Nov 7, 2014
- Michigan
2011 Yamaha apex se
How hard to install. What's so nice about the schmidt? setup
02ViperMody44
- Jan 26, 2009
- Utica, NY
2013 Yamaha XTX
- Old Forge, NY
- YAHOO
Smoother take off, can enter in and out of a garage without spinning the track. Doesn't annihilate the track as much out of the hole for better take-off. Not hard to install at all. I lost some top-mph with the Ulmer kit. Went to the Schimdt bros. and have a faster speed on the gauge. But then again, I also had them overdrive my primary, which may have been a big factor in that too. But as far as install, if you can turn a wrench, you can definitely install their setup.How hard to install. What's so nice about the schmidt? setup
sideswipe77
- Nov 7, 2014
- Michigan
2011 Yamaha apex se
I can turn a wrench just never did one.
josnow
- Dec 12, 2014
- CMass
- 2005 Rage
Same improvements with the BOP spring for $20
sgauthier
- Mar 5, 2009
- 2011 Apex XTX
i've got the spring as well as the clutch kit from Schmidt for my 2011 XTX. works good and the clutch kit has good strong mid-range pull but i was over revving by 150-200 rpms or so, so i added weight to the tips but haven't had a chance to try it again.
if just the spring is all you need then i would think the BOP spring would be a good option as well. seems to be a lot of people on here that have it and really like it as well.
Quince
- Jan 25, 2015
- 07 apex attak
Dumb question idk but what's the "BOP" spring?
Sent from my LG-H831 using Tapatalk
sgauthier
- Mar 5, 2009
- 2011 Apex XTX
Barn of Parts. they are a vendor
Quince
- Jan 25, 2015
- 07 apex attak
ThanksBarn of Parts. they are a vendor
