I was wondering if anyone knows if I can just swap the adjustment on my 09 RTX (needs a flat screw driver) with the 2011+ knob for the rear shock?
Would the shock loose it charge if I back out the screw all the way?
By looking at it at the dealer it looks the same except for the knob is screwed in where the screw goes.
The dealer was not sure so I figured I would ask here. It would make it a lot easier to make adjustments to the shock on the trail and according to the Port Yamaha site it would not be an expensive modification at all.
It doesnt allow you to remove the screw all the way.Just enough to get the adjustments.Is a circlip to stop from total removal.If you were able to remove the screw then yes you would lose oil and pressure.
