Ellsworth78
- Jan 7, 2021
- Michigan
- 2011 Yamaha venture lite
So I was getting an error code 67 on my venture lite, after a ton of research I find out that my wiring harness is wrong, previous owner had their hands in it I’m guessing....so I bought a harness for my exact year sled, install it for the sled up, everything is great until I let it run for about 15 min and it starts flashing the same error code 67....has any one had this issue? I know if the the FAQ section but no one really explained what they had to do to fix the problem
Mooseman
- Nov 3, 2009
- Greely, Ontario
- '07 Venture MP (gone)
'07 Phazer FX (gone)
'09 Phazer GT (gone)
'10 Nytro FX (son's)
- Greely, ON Canada
Info on Error Code 67
Although that is for a Nytro, seems to be an issue with the oil pressure sending unit. Did you try replacing it?
Ellsworth78
- Jan 7, 2021
- Michigan
Yes it’s the oil pressure sending unit, I’ve done everything but replace it, because it’s close to 250 bucks for a new oneInfo on Error Code 67
Mooseman
- Nov 3, 2009
- Greely, Ontario
- Greely, ON Canada
Ouch. Yeah, that hurts. Maybe try a used one? Check with Barn of Parts for one.
Ellsworth78
- Jan 7, 2021
- Michigan
Ok thanks for the help! I was trying to get it running right cause I had a guy lined up to buy but I guess he’s still going to buy it and fix it himself! Lol not gonna argue with him thereOuch. Yeah, that hurts. Maybe try a used one? Check with Barn of Parts for one.
