icebreaker
- Aug 18, 2010
- Southern wisconsin
- 2011 xtx
Just bought a new 2011 apex xtx and was wondering on any performance upgrades that actually work, like clutching or gearing to make it quicker off the corners. I don't do any lake racing. Maybe drag race my buddy's f7 once in a while witch I haven't done yet. I do more aggressive trail riding. Don't know what is the best bang for the buck on the 2011 xtx because of the 2011 power increases over the older ones. I have had 2006 and 2008 in the past and ran them all stock. Would really appreciate some input. Thanks
gsxr
- Feb 24, 2006
- BRACEBRIDGE , ONTARIO
- 2023 SRX
13 mm sway bar
Olins up front
mcx turbo
studs
other than that , a great ride !
Olins up front
mcx turbo
studs
Super Sled
- Feb 25, 2009
- Summit X
I've heard a Power Commander 5 is required if you actually want to see the claimed 161 HP's, other wise is more like 150 HP in stock form as yamaha leaned these sleds out so bad for emissions.
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
Since you have power steering, you'd really benefit running aggressive skis...much needed imo.
budman 1000
- Jan 22, 2010
- Saskatchewan
- 2023 Yamaha LTX GT, 2017 Sidewinder XTX LE 137; 2015 Apex xtx, 2010 Nytro xtx turbo, 2008 Apex GT 40th, 2008 nytro rtx, 2005 RS Vector MTN turbo, 2001 VMAX 600
I've got that very sled and love it; I would drive it first before you do any changes as you may be quite surprised in the difference from the older apex models, this thing rips and is awsome in the trails, carves corners like on rails and launches out of corners. sliders suck bad though and you can't go by the old thinking like on the older models that they wear down so far and then don't wear anymore;these sliders melt at will even on decent trails and the other yammies with you have no trouble, hmm! On groomed trails the ski's could be changed to something better. great fuel mileage and fun sled to ride, enjoy your new sled.
X2. This is an intermintant issue that has do due with the knock sensor, and poor fuel quality at times....very finicky. PC-V should fix this issue per A. Ulmer. Should be verified as winter progresses. Brother just bought this from AllenSuper Sled said:I've heard a Power Commander 5 is required if you actually want to see the claimed 161 HP's, other wise is more like 150 HP in stock form as yamaha leaned these sleds out so bad for emissions.
icebreaker
- Aug 18, 2010
- 2011 xtx
Ok I will just ride the heck out of it and see how different it is to the old apex. I kid of figured that more carbide or aggressive ski because of the power steering. Whats your thought on a bigger sway bar?budman 1000 said:I've got that very sled and love it; I would drive it first before you do any changes as you may be quite surprised in the difference from the older apex models, this thing rips and is awsome in the trails, carves corners like on rails and launches out of corners. sliders suck bad though and you can't go by the old thinking like on the older models that they wear down so far and then don't wear anymore;these sliders melt at will even on decent trails and the other yammies with you have no trouble, hmm! On groomed trails the ski's could be changed to something better. great fuel mileage and fun sled to ride, enjoy your new sled.
duhr8m
- Oct 27, 2007
- Minocqua WI
- sidewinder, SRXs, snow scoot + sport, vmaxs, enticers
it is bigger 11.7
sx7001
- Jun 28, 2003
- Sidewinder
Let it break in good before you start spending $$$ on clutching. For your riding style you should be more than happy with the way it is.. Play with the suspension settings if you feel the need to suit how you ride. Fuel quality is huge on this motor. A Pc5 will make the last 15% of the throttle useable. Ulmer has good mapping but I ended up adding a tad more after 80%. Did a lot of testing at the end of last season on perfect lake conditions and it's definitely faster on the top with a Pc5. Oh yeah, it will burn more gas to. Don't be alarmed by the speed you see on the speedo, the 11's are way more accurate than the old one. I passed my buds 06 GT @ 190kmph and his was reading 207kph.
Larry
Larry
Malibu
I geared mine down two teeth.from 23 t to 21 t.rockett on snow;-)
icebreaker
- Aug 18, 2010
- 2011 xtx
Did you have to change the chain?Malibu said:I geared mine down two teeth.from 23 t to 21 t.rockett on snow;-)
Malibu
No.my dealer did it in one hour;-)21t is the smallest before you have to change.
yamahahaapex
The powercommader fixes the cold start problems on the '11 apex. Started properly in minus 20 weather and even pulling it on a trailer in almost -30c temps for 30 miles it started like it just came out of a warm shop. Excellent! Not to mention it pulls like a damn once a guy finally gets going on the 6" of loose stuff
larsd
- Nov 7, 2011
What RPM do you now need to get going? I must give mine close to 4000 RPMs before it takes off, does anyone have any thoughts whether I should gear down or change the clutching?
I`m not that interested in top speed, response and action on low rpm is more appreciated.
icebreaker
- Aug 18, 2010
- 2011 xtx
There has been some previos posts about the rat weights. Anybody still using them? do you guys like them?larsd said:Malibu said:I geared mine down two teeth.from 23 t to 21 t.rockett on snow;-)
