MDGFLHR
- Dec 13, 2016
- Windsor Maine
- 2011 Apex SE
I have a 2011 Apex SE love the sleds have roughly 4500 miles on the clock. I had previously a 06 RTX and 09 LTX. So far my 09 has been the fastest one top end 117 gps. My mods on the 2011 are PCV with Ulmers map airbox mod bullseyes in lid and clutching. Running 135 studs best I've seen is 108 gps. I'm debating trying a set of drag n flies as those weights worked awesome on my 09. I'm currently running stock gearing and know it's too tall for stock motor. What have people found to be the best gearing. I ride in maine so conditions can be hard hard pack to really loose. I know conditions definitely effect top speed. Anyone try the drag n flies in newer Apex? What was the results? I know the 2011 is quicker mid range but hoping for at least 110 on good conditions. I've checked the exup and it's spot on. Any suggestions would be greatly appreciated ride safe
sounds like you want the ltx gear ratio in the chain case as they where geared down one tooth over the standard sleds for the long track.
