09nytro
Hahahahaha..... My sled handles awsome may you dont know what you are doinggun nut said:That's all we need. A bad handeling sled with more power.
Eagle1 said:Have you guys been hanging around with Charlie Sheen?
AGREED! My dad and I absolutely hated his Attak, especially when he switched to a Nytro. It doesn't matter how you ride...if you take a little time and money to set it up right, the only thing an Apex has over a Nytro is fuel tank size, wind protection, and a better sounding engine. The riding position of the Nytro is 1000000x better than the Apex, suspension is too, as well as fun factor. Believe it or not we couldn't figure out how to get rid of the darting on my dad's Attak. It had slydogs, Bergstroms w/ shims/ski savers, and the half iron pipe trick under the ski, and it still darted worse than the Nytro!berge75 said:dirkdiggler said:MCApex44 said:X2...My nytro turns just fine. IMO, when it comes to complaints about handling/cornering on the the Fx Nytro there are two things to consider...you guys either dont have it set-up right or you are not riding it right.
I owned one so i can say this "it sucks in the corner's. I'm a different rider on an apex or a vector. the Nytro is good for one thing BUMPS and ditch banging.
Dirk, I have both the apex and a nytro xtx, and the xtx properly set up will run circles around the apex when woods banging. I would be willing to bet $100 on it. The xtx will require more body english, but will stick to the corners where the apex will not. The nytro took a little time to set up but will reward you with great striaght line handling, jams through the big moguls way better, better milage, and damn near as fast with exhaust. I have a choice to ride one or the other, and I always go with the xtx, funnest sled I have ever owned.
yamahaapex1000 said:what are you doing here? why are you running your mouth off on this forum? did you see a green homepage with a cat on it, beacouse i think you are lost. This is a yamaha forum, and people like to read valid opinions.
ruffrider said:AGREED! My dad and I absolutely hated his Attak, especially when he switched to a Nytro. It doesn't matter how you ride...if you take a little time and money to set it up right, the only thing an Apex has over a Nytro is fuel tank size, wind protection, and a better sounding engine. The riding position of the Nytro is 1000000x better than the Apex, suspension is too, as well as fun factor. Believe it or not we couldn't figure out how to get rid of the darting on my dad's Attak. It had slydogs, Bergstroms w/ shims/ski savers, and the half iron pipe trick under the ski, and it still darted worse than the Nytro!berge75 said:dirkdiggler said:MCApex44 said:X2...My nytro turns just fine. IMO, when it comes to complaints about handling/cornering on the the Fx Nytro there are two things to consider...you guys either dont have it set-up right or you are not riding it right.
