2012 nytro xtx build
I have to hold off on alignment shocks are not here yet. When I installed the relocation kit and the riser the brake and the parking brake are tight. Only way I see getting more slack in lines if I cut plastic shroud where brake lines run.
I had to trim mine right where the upper support is or it would not clear. Kinda a plus though, lets out more heat and more room for control lines
New seat
I was going to purchase WRP seat but a used nytro mountain mod seat showed up.
shocks installed
Finally shocks showed up and front end finally taking shape.
suspension
Front suspension alignment is done just deiciding what skis to go with curves are on top of the list. Took rear suspension out today rear shocks will be serviced by who is the question and installing pioneer hyfax extender wheel kit.
I have read about the star kit. I want to ride the sled first this coming winter go from there.
tunnel cooler
Tunnel cooler installed just got to get some bigger clamps.
vent
Put on panel vent.
tunnel supports
Tunnel supports done. Waiting for rear shocks to be done.
Looks great so far!
Nice work. ;)!
Thanks still more to do.
