vsmpowered
- Feb 16, 2009
- Rochester , NY
- Nytro xtx Viper ltx se
whats the deal with brake cylinder? because mine locked up its 2014 ltx se from overheating or too much fluid
fastfreddy
- Mar 12, 2009
- Yamaha / arctic cat
All that was said to update it ! Arctic keeps you in the dark !whats the deal with brake cylinder? because mine locked up its 2014 ltx se from overheating or too much fluid
TD Max
that is correct ! this was the first meeting for the dealers and it was a mess of sorts ! November is the time frame set for reflashing and update kits for the February build units. No comment was made on the spring to September units except the September and later will have bigger oil tanks with dipstick instead of sight glass!
Mine has a sight glass and was just built. I can't say exact production date, but it did not land at dealer until October.
DranttelSS
TY Advertiser
- Oct 9, 2014
- St. Peter MN
- 2007 Yamaha Attak
Units built after 9/17 have the dip stick. Units before 9/17 still use the sight window
TD Max
Just my luck.
Is there a true benefit to the new style or just a simple running change?
DranttelSS
TY Advertiser
- Oct 9, 2014
- St. Peter MN
- 2007 Yamaha Attak
Just my luck.
The benefit is more for the mountain sleds. The new tank has different baffles which help for long steep climbs and frequent rollovers. It also has slightly increased capacity.
yamadoo
- Jun 3, 2003
10 Vector LTX Blue 9kmiles
11 Venture GT 4k miles
86 SnoScoot(2) for grand kids
I have the site glass as well, seems simpler than dip stick.
Wonder why the change? Dumb ? As is always $, I know.
If you roll it without a rollover valve onto the right side you will quickly find out why. Loses prime and dumps oil out.
TD Max
So does the new style sump reduce or eliminate the need for a rollover valve?
Remains to be seen. Phazer and nytro do it if rolled on left. Viper on right. A combination of the 2 would work except for full rolls. Rollover valve is only thing to truly stop that and that check ball in viper box has caused issues for some.
fastfreddy
- Mar 12, 2009
Date of production on back of tunnel , we just received two more Wednesday and they are April build also!Mine has a sight glass and was just built. I can't say exact production date, but it did not land at dealer until October.
TD Max
Mine is 4-2014 as well. Maybe the spring orders got their VIN label created based on order date? I finalized right before the deadline.
So now the question goes to reflash as well...
sneakattak88
still waiting for call from dealer, has not shown up yet
TD Max
Mine kind of looked like it was built then sat around quite a while. Dealer did a wash, but the black plastic underhood parts looked like they sat alongside a dusty road with 3m trucks going by. Gray dust.
fastfreddy
- Mar 12, 2009
just looked at a October build and the new parts are in it . I would think that the updated ecu would be in that run also but , Yamaha is pretty quite...My take on this is that the fix has been applied at the production end and that the hardware and software required for a field fix is just being finalized.
fastfreddy could you confirm this?
