CooperT
- Jan 23, 2015
- Fergus, Ontario
- 2018 LTX DX
2016 RTX SE
Girlfriend was complaining about major darting on her sled yesterday. I said, you’ll get used to it. She could barely keep, so I got thinking maybe she is right. So I hopped on it and I must say it was brutal! Same procross skis as my ltx dx. 6” carbides, limiter strap on middle hole now (was on lossest setting), rear torsions were on middle setting and now on lightest setting, fox qs3 shocks all set on softest setting. My sled has no darting whatsoever and is effortless to drive. I’m swapping my dual 6” carbides on to her skis this morning and I’ll take the singles and see if it makes any difference.
Any thoughts on what the problem could be? She said the tuners were way better. Trails are flat and hard right now. Again, my sled is setup perfect and she doesn’t want to give it back! Lol
ishpeming fan
- Feb 5, 2017
- Bristol WI.
- 2019 ZR RR 8000
what skis are on the sled? Limiter strap sounds like it should be loosened to one hole below stock and try tightening the spring on your front skid shock. the dual carbides will help as well. this should help get some weight off the skis and help her out.
Kkurz
- Nov 1, 2016
- Peterborough On.
- 2014 XF7000 Sno-Pro Limited
(Yamaha powered)
First thing you need to do is check the toe in. It's where everything starts.
CooperT
- Jan 23, 2015
- Fergus, Ontario
- 2018 LTX DX
2016 RTX SE
So, they’re procross cat skis on both vipers. I run dual carbides on mine. Hers had the AC single carbides, which are junk btw. I switch my skis over to her sled and I used hers as a test to see if maybe it was just the carbides. Sure enough, now hers is amazing and mine darts all over!! So now I need to go buy another set of dual carbides. The limiter straps are on the middle hole as there is only 3 holes. Toe in is fine, just like my sled.
Kirt70camaro
- Oct 20, 2018
- DAVISON Michigan
- XF7000
Bought my XF7000 last year. First ride was darting all over. Took it to the dealer they said take off the new single carbides and install dual. I was pretty sceptical but did it anyways. Sure glad I did it because now it handles awesome.
mtcooler
- Dec 16, 2013
- Newton Wi
- 2014 ZR 7000 LTD Sno Pro
Are you all running the cat dual staggered carbide?
CooperT
- Jan 23, 2015
- Fergus, Ontario
- 2018 LTX DX
2016 RTX SE
Mine aren’t staggered
srvfan
- Nov 9, 2004
get a set of snow trackers will go dead straight..... assuming that skis have correct toe out
WinderFab
- Mar 1, 2009
- Woodbridge, ON
- 2020 Sidewinder Ltx GT
Snow trackers have to be set with 0 toe out, skis should be parallel to each other.
Best investment I have done to my sled by far..
CooperT
- Jan 23, 2015
- Fergus, Ontario
- 2018 LTX DX
2016 RTX SE
I have slim Jim 6” duals. There’s no darting at all. I can ride with one hand over 100km/hr...it’s like driving a car. It’s definitely a struggle with the single 6” carbides, they should be illegal!
TPAY243
- Apr 14, 2013
- Northern Wis
- 2020 Yamaha Sidewinder LTX SE
Why would you run the dulley's on your sled and singles on your girlfriends sled. If she is not having fun while on the machine she will lose interest in a hurry. If she likes the tuners put them back on. What works for you may not work for her, if you leave the cat ski on put a set of the staggered cat carbide on, put the limter back to the std pos, rear springs on the softest setting. What is the pre load on your front and center shock springs.
CooperT
- Jan 23, 2015
- Fergus, Ontario
- 2018 LTX DX
2016 RTX SE
Did you read anything above?! Lol
I Swapped my skis onto her sled (with the dual carbides) as a test to see if it was in fact the carbides, and it was. The dual carbides worked on her sled just like they do on my sled. So I ended up riding with the singles on the second day. Trust me, I hear what your saying about keeping her happy!
CooperT
- Jan 23, 2015
- Fergus, Ontario
- 2018 LTX DX
2016 RTX SE
She likes limiter on middle hole, torsion springs are on softest setting.
Qs3s are on softest setting all around.
Not sure about preload on springs though, I would assume they’re still factory set.
DranttelSS
- Oct 9, 2014
- St. Peter MN
- 2007 Yamaha Attak
Should be fixed when you put the Slim Jims on. That what I ran on my Viper and now my Sidewinder with excellent results.
TPAY243
- Apr 14, 2013
- Northern Wis
I read everything, what i ment was you never should have started her out on a singal carbide especially 6 inch. Why do you have the dulley's on yours, because it darts around like crazy without them. These rider foward sleds have a lot of ski pressure and it is hard to get a single carbide to work with out the darting. Some people are more worried about turning and live with the darting. I just adjust the way I drive when the conditions change i can't stand it when the machine im driving is all over the trail.
