Xrx1dude
Picking it up Monday, this is the most excited about a sled I’ve been since my 03 Rx1
03RX1-ER-LE
Bleed BLUE
- Feb 22, 2008
- 2011 Apex XTX 12,497 miles
2009 Apex ER 8,169 miles
Tow Vehicle
2021 Wolverine X4
- Livonia Michigan
SWEET! I am sure it is going to feel like the winter season is going to be a year away.
As I stated above 106 GPS with a ice storm.I saw mid 90s on the trail with my 2016 XTX 1.75". The 1.75" is amazing in loose snow and pulls hard past 80, but top end and gas mileage is definitely sacrificed with the 7 tooth drivers.
What are you seeing for top end with the 1.25" track and 8 tooth drivers?
I would think 110 would b achievable with a 1.25
Teamblue4
- Feb 20, 2008
- Il.
- 2012 Apex XTX
2013 Apex SE
2014 Apex SE
2014 Apex XTX
108 mph with a 1.326 Cobra.As I stated above 106 GPS with a ice storm.
sideshowBob
Over the past couple years I have really noticed how realistic everyone's top speed numbers have become since the ability to GPS sleds either with a smart phone or a hand held GPS.
Gone are the days of the claims of 120mph plus stock Apexs pushing a few inches of loose snow! LOL
The 70s and 80s were probably the worst for ridiculous top speed claims.
I think everyone has come to the realization that speedos are dream meters and a sled with a deep lug track that consistently breaks 100mph is a fast sled!
Very refreshing.
kinger
WOW That is a clean sled!!! Looks better then new, polished tunnel, led hand guards with mirrors, cleanest stock rear suspension I have seen too! Great find!
The 18 Apex that I switched drivers on now reads much lower. Any idea on if the speedo can be recalibrated?Over the past couple years I have really noticed how realistic everyone's top speed numbers have become since the ability to GPS sleds either with a smart phone or a hand held GPS.
Very refreshing.
The other option would be to somehow find a speedo pick up sensor-sprocket with more teeth.
sideshowBob
An under indicating speedo is the opposite issue of most sled speedos.
I have never heard of anyone recalibrating Apex speedos so more teeth on the speedo trigger gear would be probably only option but would likely need to be a custom built item.
Yes, I think that's the only way.An under indicating speedo is the opposite issue of most sled speedos.
03RX1-ER-LE
Bleed BLUE
- Feb 22, 2008
Tow Vehicle
2021 Wolverine X4
- Livonia Michigan
Tempting......16 - 18 on my radar to get the single shot air ride.
https://detroit.craigslist.org/mcb/snw/d/new-baltimore-2016-yamaha-apex-tx/7289509461.html
However my goal this year is buying a Wolverine X4 as soon as they can build one due to the Semi Conductor shortages.....
greatwhite89
- Mar 19, 2015
- Oshkosh, Wisconsin
- 2020 Yamaha RS Venture TF
- www.snowflapjunkie.com
03RX1-ER-LE
Bleed BLUE
- Feb 22, 2008
Tow Vehicle
2021 Wolverine X4
- Livonia Michigan
Nice! Would be even better if XTX
To those with the 16-18 Apex XTX. The front idler shaft wears out quickly, at least on the two I had come through here recently.
I just threw it all away, and used the rear idler cross shaft from the 98-04 sleds. Then use two new wheels complete with 6205 bearings.
good to know. have to check mine as in garage atm for its service.
mikextx
- Feb 19, 2017
- holland MI
- 2017 apex xtx
- Holland MI
Do the 8 tooth driver sleds use the same speedo gear as the 7 tooth? I know on my old proaction sleds, the gears were toothed accordingly. Maybe you just run the appropriate gear?The 18 Apex that I switched drivers on now reads much lower. Any idea on if the speedo can be recalibrated?
