RSR_Performance
- Mar 21, 2018
- Tennessee
- 2017 Sidewinder 2014 SX-R
2019 Yamaha SX-R concept snocross sled. This thread will be dedicated to answer any questions about the sled. Sled started as a Viper.
Here's the things we had to do.
Fabricate brackets for radiator and front nose
Remove reverse completely
Remove the TORS system
rewire the ignition switch and ad push button start
change out STOP/RUN button
1.75" Camo snocross track
20/49 gearing
Fabricate stock belt guard
relocate and change coolant reserve bottle
Fabricate custom collar for chaincase
new plastics
new seat
new headlight
Fox EVOL RC2 shocks set up for snocross
Tunnel reinforcements (front and rear)
Throttle block
snocross snow flap
Plus more
20/49 gearing
new plastics
new seat
new headlight
Throttle block
snocross snow flap
Plus more
RSR_Performance
- Mar 21, 2018
- Tennessee
RSR_Performance
- Mar 21, 2018
- Tennessee
I’ll be posting a complete parts list(keep in mind 90% of the parts required fabrication. I will be selling full conversion kits as well. Ask any question you may have.
Mike P
- Nov 18, 2015
- Berlin CT
- Sr Viper R-TX SE
- Berlin CT
Is it a 129" track. Any power adders?
What about the radiator? You remove it?
RSR_Performance
- Mar 21, 2018
- Tennessee
Yes, it's a 129"Is it a 129" track. Any power adders?
RSR_Performance
- Mar 21, 2018
- Tennessee
It has a stock air box on it, did have a K&N kit on it. Has a OSP can and a Ulmer clutch kit with power commanderIs it a 129" track. Any power adders?
RSR_Performance
- Mar 21, 2018
- Tennessee
No it still has the factory radiator, just had to make a bracket for the support. We had to completely modify the front nose for it.
What are your plans for getting the hot air in and out?No it still has the factory radiator, just had to make a bracket for the support. We had to completely modify the front nose for it.View attachment 139588 View attachment 139589
RSR_Performance
- Mar 21, 2018
- Tennessee
Progress pics.
RSR_Performance
- Mar 21, 2018
- Tennessee
The fan is still there and there are vents on the underside. We ran it for 20 mins in 60 degree weather and she stayed at 165What are your plans for getting the hot air in and out?
mikextx
- Feb 19, 2017
- holland MI
- 2017 apex xtx
- Holland MI
Why did you remove the reverse? Because the original sxR didn't have it?
snowfever27
- Jan 7, 2015
- Vermont
- 2015 Arctic Cat XF7000
2009 Yamaha Nytro XTX (sold)
2007 Yamaha Phazer FX (sold)
2005 Ski-Doo MZX 800 Adrenaline (sold)
2003 Arctic Cat F7 EFI (sold)
2007 Yamaha Attack
2009 Polaris 600 Dragon SP
- Vermont
Probably removed reverse for weight savings.Why did you remove the reverse? Because the original sxR didn't have it?
RSR_Performance
- Mar 21, 2018
- Tennessee
For weight. Removing the reverse, wiring and switch saves almost 11lbsWhy did you remove the reverse? Because the original sxR didn't have it?
aaronbellmx355
- Mar 13, 2013
- vernon ny
- 2009 Nytro RTX push turbo
2014 Viper XTX
sweet build!
- Status
