Muskrat62
- Dec 19, 2016
- Cannon Falls, MN.
- 2020 SRX, 2018 MXZX, 2016 Blizzard, 2003 RX1 Turbo
Would someone please tell me how the extrovert drivers are held In Place on driveshaft? 2020 SRX Are they pressed on and locked on somehow? Mine are not in ideal place for my track window and it is causing me alignment and wear issues. Here are a couple pictures. One driver rubs on side of track while the other is centered nicely. Thoughts?
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
There pressed on and can be moved if needed.
Byam
- Apr 23, 2015
- En Motoneige
- SW2017
custom
Pto side? (Clutch)
Since 2014 (viper) i have seen lots of them being to much inside. Remember the space between the drive shaft bearing and the litle space we have between it and the clip...
Maybe thats were they got it wrong a bit there. Theory...
Muskrat62
- Dec 19, 2016
- Cannon Falls, MN.
Thanks, I take it to move the drivers you have to take the drive shaft out and use a press??
no1b4me
- Dec 31, 2016
- 2019 ZR9000 Ltd iACT
You are correct unfortunately.....
NYTurbo
- Sep 26, 2017
- Ottawa
- Sidewinder
What is the distance between the extroverts inside measurement
TPAY243
- Apr 14, 2013
- Northern Wis
- 2020 Yamaha Sidewinder LTX SE
Good luck I had the same problem with my Viper I switched to inverted drivers and that solved the problem. Way easier on the track much easier to adjust track and all n all quieter. I also think it might have gave me a little more on the big end. The track moves so much easier it's not even funny.
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
What do you mean by inverted drivers?Good luck I had the same problem with my Viper I switched to inverted drivers and that solved the problem. Way easier on the track much easier to adjust track and all n all quieter. I also think it might have gave me a little more on the big end. The track moves so much easier it's not even funny.
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
The drivers do not go through the windows on the track.. They stay on top of the track. They "grab" the track differently. If you see these drivers you will notice right away DMC. I have a 2021 8000 Cat that has them stock.. And yes they are usually faster UP TOP. Not saying the 21 Cat is fast up top..
DMCTurbo
- Nov 12, 2005
Thanks JonThe drivers do not go through the windows on the track.. They stay on top of the track. They "grab" the track differently. If you see these drivers you will notice right away DMC. I have a 2021 8000 Cat that has them stock.. And yes they are usually faster UP TOP. Not saying the 21 Cat is fast up top..
Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
Extroverts are need on sleds with lot’s of power, to help stop track ratcheting.
TPAY243
- Apr 14, 2013
- Northern Wis
Ya says who if all your doing is racing you may have problems, trail riding your fine I know guys useing them on tuned Winders with no problems. You do have to run your track a little tighter tho
Byam
- Apr 23, 2015
- En Motoneige
- SW2017
custom
Asphalt or standard drivers will always be better for free wheeling. Big difference on gaz and top speed. Many many people run 11 *asphalt 2.52
Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
Not a racer just a trail rider/racer like most guys right!
Yep tighter and tighter and still ratchets on hard conditions if studded!
I do agree that non extrovert drivers free wheel easier, but when big power is there even on trails, it will ratchet and can hurt your track and drivers! Been there buddy!!
Turboflash
- Mar 18, 2019
- Southern MN
Re: track tension
Here is TD's recommendation regarding track tension for high performance:
- Make sure you have a tight track (must not hang at all when lifted off ground, must be hard to push off the front bogey wheel). It is highly preferable to have a 4 wheel kit upgrade to maintain reliable track tension especially when running high power and or fast speed. Running a loose track will rob lots of top speed (as track baloons from centrifugal forces). Also loose track can cause ratchening of track drivers which will damage them and or the track. Radar running require a VERY tight track as high speed cause expansion.
