2021 Delivery
Brought mine home today now time to do some add onsView attachment 157198
Add ons? It looks like you're already on your way.
I can see three add ons already on your sweet looking new SRX.....
-4th wheel kit rear axle
-Bling bling billet wheels
-larger tunnel storage bag
Keep us posted on your future add ons.
Thanks guys I did add an x-lg tunnel bag for my spare belt. I got my billet wheels and drop down axle from trick-toys. Little pricey but they look great. I ordered the 9 inch wheels and wasn’t aware I had to custom the shaft with the transfer blocks on it until my dealer was almost finished with the install. Called them and explained the issue that the shaft won’t go back on so they said I had to cut the shaft even with the blocks on each side and that the new axle is a lot more beefier that it’ll be fine but still need the blockers on. My dealer said it’ll be fine so my warranty will still be good. If you order the 8 inch wheels should be bolt and go
Good eye Vx1R
Blevis213 does the extra large bag use the same mounting locations as the stock medium bag does?
Cat or Yamaha came up with a great way to fasten the bag to the tunnel, I was thinking of getting the extra large bag for the longer trips..
Sweet looking sled...
not sure i had my dealer put in on but i do know they had to drill 2 new holes
Thanks..
When you get a chance can you look and see if there are 2 or 4 of those twist knob like locks that hold the inside of the bag down.
I had my dealer install a Large size bag. It needed new holes drilled.
Good eye Vx1R
Did the dealer do a trade on the original tunnel bag ?
I am looking for one , to put on my 17 Winder.
I will say that I installed the extra large bag a couple years ago and the extra space is great, but I would advise against the extra large bag and go with the large bag instead. The large bag just plain looks and fits MUCH better as it looks stock and the extra large bag seems to overhang the tunnel. Also the tab that holds the seat bolt tends to cut into the material on the top of the bag so that needs to be addressed by filing the corners off of it.
