number1kyster
- Dec 10, 2004
- Vermont
- 2018 SW RTX SE
My dad is on a saddlebag trip with his brand new stock 2022 XTX LE. It has run out of fuel twice with 1/4 tank of fuel reading on the gauge. Today it was 84 miles of groomed trail. When he makes it to the pump he is within 2 liters of the sleds he is riding with. Thoughts?
Pinched vent hose?
Fuel pump issue?
Pinched vent hose?
Fuel pump issue?
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
I would remove the pump assembly and get a look at the fuel pickups in the tank. Make sure they are sitting where they belong and in place. As long as you are in that far in, run the return line back above the fuel slipper to prevent starvation when low on fuel too.
number1kyster
- Dec 10, 2004
- Vermont
- 2018 SW RTX SE
This must be it. He just told me it starts cutting out going down hill when he gets to 1/4 tank, but will run fine on the flat.
justinator
- Mar 25, 2007
- Maine
- 2023 Arctic Cat Riot 9000
If you remove the sending unit you can look in the tank with a flashlight and see exactly how the fuel pickups are sitting in the tank. There is one on each side of the tank. One of them can occasionally get fetched up when sliding the pump assembly in, its not common but does happen.
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
All good things listed above.. Any chance you have a way to check fuel pressure? Possible bad fuel regulator?
