Angela 007
- Feb 17, 2026
- Nova Scotia
- 2022 Viper, 2018 Viper
2012 800 Polaris Switchback
I was riding 2022 Viper on the weekend and stopped to take a picture and out of the blue the sled shut off.
Started again and went down the trail not a very far distance, sled was sputtering and surging, thought it was a fuel pump issue. Some time you would hear the pump start up , other times, not at all. So, now It doesn't seem like that is the problem , tried a new fuel pump and that won't start up. Anyone else have this happen ? He switched the relays
So it appears there is no juice to the fuel pump, the dash is reading -40 coolant, and the backup alarm is coming on, but it is not in reverse.
Relay in the fuse box?
Angela 007
- Feb 17, 2026
- Nova Scotia
no he tried switching them. So it appears there is no juice to the fuel pump, the dash is reading -40 coolant, and the backup alarm is coming on, but it is not in reverse.Relay in the fuse box?
All you can do is start the track through the harness looking for a short.no he tried switching them. So it appears there is no juice to the fuel pump, the dash is reading -40 coolant, and the backup alarm is coming on, but not in reverse.
Angela 007
- Feb 17, 2026
- Nova Scotia
He's thinking it could be the ECU...All you can do is start the track through the harness looking for a short.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
Check battery cable connections.
I have had them loosen up before and cause issues.
Angela 007
- Feb 17, 2026
- Nova Scotia
Thanks, he tried a ECU off a different sled, it starts and the backup alarm, and coolant temp seems okay, so ordered a used ECU.
