Sr_Viper_RTX
- Jan 28, 2018
- Maine
- 2016 Yamaha Sr Viper RTX LE
I have a 2023 sidewinder that sounds like it’s hitting the rev limiter when I pin it and sometimes around 3/4 to full throttle it will cut out. It is tuned and has an mbrp race can on it. Just wondering where to start or what to check
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
Did you clutch for the tune?
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
More details. RPM's when this cut out happens?
Fords4life
- Dec 7, 2021
- South Dakota
If it's under the rev limiter when it cuts out an over boost will do it.
Sr_Viper_RTX
- Jan 28, 2018
- Maine
So it doesn’t always do it I went this past weekend and when I pin it and get to about 8000 rpm and it cuts out and puts up a code sd-25
WinderFab
- Mar 1, 2009
- Woodbridge, ON
- 2020 Sidewinder Ltx GT
Sd-25 is a boost leakSo it doesn’t always do it I went this past weekend and when I pin it and get to about 8000 rpm and it cuts out and puts up a code sd-25
What tune?
Sr_Viper_RTX
- Jan 28, 2018
- Maine
It has a precision efi 2 done through local dealershipWhat tune?
Sr_Viper_RTX
- Jan 28, 2018
- Maine
Where is the best place to start to look?Sd-25 is a boost leak
number1kyster
- Dec 10, 2004
- Vermont
- 2018 SW RTX SE
Tighten all clamps, check the charge tubes for splits.
What are you running for clutching?
