Eugenius.w
- Feb 12, 2019
- Denare Beach
- Yamaha Sidewinder BTX
Definitely possibleOne other thing that could be happening is that you are tapping the rev limiter.
My thoughts as well.
stevewithOCD
Yamaha, Make me Come Back
- Jan 1, 2008
- Live CT Ride MAINE
- 900 R
2006 Apex RTX
The first year of the Winder, as aftermarket muffs were coming out, it was reported they would over-boost with no tune.
Eugenius.w
- Feb 12, 2019
- Denare Beach
It’s definitely making sense. I’m installing the old muffler tomorrow.The first year of the Winder, as aftermarket muffs were coming out, it was reported they would over-boost with no tune.
zxtyler
- Dec 12, 2020
- Michigan
- 2020 SRX
A bit off topic but do you fellas know what rpm the limiter starts at ?
Turboflash
- Mar 18, 2019
- Southern MN
I've seen your problem before and it definitely sounds like over-boost. You'll find out when you try the stock muffler.
If I remember correctly, I think 9600A bit off topic but do you fellas know what rpm the limiter starts at ?
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
Wait, you're running an aftermarket muffler on a stock sled?
If you are, that IS the problem. It will overboost and hits the boost cut, killing the sled momentarily. On top of that, most mufflers will also allow the engine to run too lean. Only one I know that does not overboost and hit boost cut and run too lean is the Hurricane Hindle.
bigwinder
- Mar 8, 2026
- Oakbank Manitoba
- 2018 Sidewinder XTX 141
Did switching back solve the problem of cutting out? My new to me stock 18 with a aftermarket exhaust is do the same thing.Thanks I will try the old muffler tomorrow
Do NOT run your stock SW with a high flow muffler! You need a tune that is catered to the higher flow exhaust and safely allows for the higher flow through timing and fuel adjustments.Did switching back solve the problem of cutting out? My new to me stock 18 with a aftermarket exhaust is do the same thing.
