STAIN
- Feb 29, 2004
- Vermont
- 2022 SIDEWINDER LTX GT
- Vermont
I am doing the first oil change on my friend’s 2024 Sidewinder GT. 600 miles. Sled has never been back to the dealer.
This oil filter was on it
Has anyone seen a Wix filter from the factory?
Then this was in the pan
And this was jammed under the chaincase
WTH!! that’s all I saw for now.
Froggy
- Apr 29, 2016
- Kipawa,Quebec
- 2020 Winder LTX SE 16600 km and counting
2016 Viper LTX LE 23986 km sold
2015 Viper LTX DX Wife's 22500 km sold
2010 Vector LTX GT 25000 km sold
2024 SRX Leftover 0 km
That's a strap for the ECU I believe, you might want to make sure everything is strapped down in the bulkhead. I did my own first oil change and chain case servicing and the gear wasn't indexed properly under the actuator for the chain case.
STAIN
- Feb 29, 2004
- Vermont
- Vermont
That is just what it is. Sucks getting my hands down there to reinstall it.
ToddMeister
- Jun 30, 2003
- Bay City, MI
- Yamaha SR Viper LTX LE
- YAHOO
- tmeister73
My 2024 LTX GT Winder also had the Wix filter installed from factory when the 500 mile oil change was done.
sxr70001
- Dec 4, 2010
- Michigan
- Sidewinder LTX SE
SR Viper RTX SE
If their good enough for Vice Grip Garage they're good enough for me.
STAIN
- Feb 29, 2004
- Vermont
- Vermont
Wix filters are actually some of the best aftermarket filters out there. I was just surprised that Yamaha would deliver the motor with that filter instead of their own.
Spaceman
- Apr 20, 2017
- Ohio
- 18 Thundercat
Mine wasn't indexed correctly either. 2024That's a strap for the ECU I believe, you might want to make sure everything is strapped down in the bulkhead. I did my own first oil change and chain case servicing and the gear wasn't indexed properly under the actuator for the chain case.
timmyz06
- Feb 28, 2018
- MTL
- switchback assault
making an oil change on the 998 is a pita!! My first one (ZR RR)and now i realised that i will have to redrain it to do the chaincase???!! There must be another way!!??
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
Typically you'd do both at the same time, but you can open the chaicase without draining the oil tank, Just pull the cover and oil tank back, the hoses flex enough and you can pull and swing the assembly out of the way.
A lot of people drill the rivets out on the chaincase side so the lower panel can be removed easily too. I use Honda plastic push pins now to hold that panel on.
When you get used to doing it, it's not that hard like anything.
