21 tooth gear
ranger1 said:
zigoapex1 said:
same thing happened to me against an etec with my 07 rtx.(first time ever,and it to be a musterd bucket uuuggggggggg!!!)he got me mid range.
I hate to say it, but those etec's are a good set up.
the rtx is a different sled than the other apex's.I had an 06 er
before this one and it had a lot more top end. 22 to 24 gear is a big difference.That 22 gear is beatiful in the beat up bumps and ditches,wack the throttle to launch you or slide your #*$&@ out of a hair pin and its dreamy coming down those icy hills.
the bad, gas milage is olny about 12, er was much better and you loose the top end. unfortunately you cant have it all but we have most of it ! :yam: :Rockon:
Yo zigoapex1, did you happen to try a 24t in your RTX? I have the same sled & was wondering if it would be worth swapping out the 22 for the 24 & the 68L chain for the 70L? How much top end you figure the 24 would have over the stock 22?
Thanks,
Darren
after reading a lot of post on this,I think the 23 is the way to go
