musselman
- Apr 17, 2009
- Fenelon Falls, Ontario
- 2019 Ren XRS 900T, 2010 Nytro RTX
Had this sled at a few dealers and they ended up putting the rear skid in different mounting holes. Does anyone know what the stock holes are and what the others positions would do?
Stubbs
- Nov 7, 2006
- Uxbridge, On, Can.
+ other gooodies
- Uxbridge ON
What are you playing with there pal?
justinator
- Mar 25, 2007
- Maine
- 2023 Arctic Cat Riot 9000
Upper holes closest to your footwells and upper holes in rear
musselman
- Apr 17, 2009
Just a buddys winder, the dealers he had it at butchered it. Now I’m stuck with fixing all the issues.What are you playing with there pal?
musselman
- Apr 17, 2009
Thanks for the reply, from my research all of Yamahas stock photos show the rear mounted in the lower hole on the xtx le. Looking at the arctic cat riot, it is mounted the same in the front however the rear is in the top hole. This is why I’m a little unsure.Upper holes closest to your footwells and upper holes in rear
justinator
- Mar 25, 2007
- Maine
I had a 2020 xtx le as well and it was mounted in the upper holes in rear as well.Thanks for the reply, from my research all of Yamahas stock photos show the rear mounted in the lower hole on the xtx le. Looking at the arctic cat riot, it is mounted the same in the front however the rear is in the top hole. This is why I’m a little unsure.
THEPASMAN
- Mar 25, 2019
- The Pas Manitoba
- 2017 Sidewinder LTX LE
There was a discussion about this last fall. I can’t find it in a search. Yamaha had done some changes I think. I can look at mine in a couple days and see where I ended up. You’ll likely get a response before that
RobX-1
- Coldwater, OH
Here are two posts I recall reading about the suspension bolt location:
https://ty4stroke.com/threads/2020-...ear-suspension-bolt-hole.160023/#post-1520752
2021 sidewinder Ltx-se rear suspension top and bottom home difference
Been hearing people move bolt in rear suspension to the top hole. What does that do? Just back bolt out and move up or a ton of work elsewhere? Thanks
musselman
- Apr 17, 2009
Interesting read, seems like there is lots of confusion on Yamaha's part. It's probably best to go by what cat is doing on the riot, it is their chassis after all.
I thought the mounting position may have been related to the front pivot arm getting destroyed, so just wanted to confirm so it didn't happen again.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
Out of the 23 sidewinder manual.
justinator
- Mar 25, 2007
- Maine
Interesting, thats not how cat mounts it in the riot which is essentially an xtx le. At the end of the day I think its a matter of preference. May need to test both mounting locations
HABS 1
- Oct 22, 2015
- corunna,ontario
my 146 se is in the top and the le are bottom like those pics say.... thinkin thy use top hole on se for stability reasons would be all i can think of with the se havin a narrower ft end
musselman
- Apr 17, 2009
Interesting info, I will have to test how it sits in each position. I was thinking the le is in the bottom hole for more ski pressure/bite for trail use.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
Trying to load a better picture.
musselman
- Apr 17, 2009
Happened to see one of these sleds at the dealer on the weekend and the rear was in the lower hole. Looks like that's how the LE's are mounted.
