Doowithblue
- Mar 17, 2016
- Waterloo ON
- 07 Mach z x (sold)
18- RTX LE
For those running hh's in their hurricane tunes. Once the sled gets some good miles on it you are going to need a hell of a lot of weight in the primary. I ordered the optional tungsten washers for mine. I honestly believe lon should be sending out a higher base weight for tuned winders. No matter what you do to a 58g base weight it's not going to be enough. And this is with a light spring. It's incredible how much faster this sled is getting with some miles on it.
- Sauk Prairie, WI
- www.ty4stroke.com
I'm thinking you'll need Daltons or STM weights with that tune when is all said and done.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
Nailed it Matty.....I'm thinking you'll need Daltons or STM weights with that tune when is all said and done.
Beerman
- Nov 22, 2004
- Plymouth, MN
- www.loyalshepherd.com
- Sidewinder LTX-SE
- YOUTUBE
- arttyszka
Why Daltons and not just a heavier base weight HH?
johan
- Jan 19, 2015
- sweden
- Sweden
- Viper Xtx mcx 270
I run viper 270 and i use hhy68. You got 270 the hhy58 is a bit light
LouTurbo
- Dec 19, 2016
- Vaughan, ON Canada
- 2017 Sidewinder LTX LE, Hurricane Tune on the fly
Pilot Skiis,
- Woodbridge, ON
Therefore will the Lonn's Big Venom not have enough weight for a 270 tune, is anyone using the Big Venom weights for a 270 tune.
TT
Do you think the HH base weight 58gr with 1/2» brase fastners (9.2gr) or 7/16» brase fastners (7.2gr) together with heavy metal washer will be too light for the 270/280 race tune?
theewarrior
With 270 race and Dalton adjustables how much weight do you think we need ?
Doowithblue
- Mar 17, 2016
- Waterloo ON
18- RTX LE
Tungsten washers and you'll be fine. Weight is weight. Don't fall for the members saying you gotta go with another brand. Not true at all.
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
Depending on which springs and helix you use, 76-79 grams for the 270R and Daltons.
theewarrior
I have thunder Products front and rear Orange Springs ,thunder products hole shot 33/35 helix, 911 cover ,153x1.75 track
Dieselxtx
- Feb 21, 2016
- Fox Lake, WI
- 2017 Sidewinder BTX LE
2012 Nytro XTX 1.75
I went to 63g base weight and it works perfect for max spool 17 TD tune
Doowithblue
- Mar 17, 2016
- Waterloo ON
18- RTX LE
Yes. Incorporate tungsten washers in the mix and you'll be fine.
Jafo1970
- Dec 2, 2016
- oshkosh, wi
- 17 sidewinder, doo 850
I was running the 280r tune, and now called 290r tune and the 58 base with tungsten washers and the big boy brass bolts at 7 grams each and it still wasn't enough. I bought the 63 gram base weights and good to go now. I believe I'm around 80 grams in the HH.
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
with what belt and setup in the back clutch?
