Pstn head
Like fatchance said maybe a bit bit tight, but I'm thinking its stretched.
STAIN
- Feb 29, 2004
- Vermont
- 2024 Arctic Cat Riot 9000
- Vermont
Mine is like that. I adjust the chain before i put the cover on so you can actually see what kind of slack you have. Finger tight, roll the track and recheck, repeat as necessary . Back off 1 turn , lock it down
My thought was (and I don't want to cause panic), maybe the chain tensioner came undone inside the case.
chaleurphantom
- Oct 5, 2009
- Northern New Brunswick, Canada
- 2018 SIDEWINDER LTX-LE 50th Anniversary
2016 VIPER XTX LE - WHITE,
2009 VENTURE GT,
1995 POLARIS INDY 500,
1984 SKI-DOO CITATION 3500
Looks a bit tight, have you had the case open?
Better place to post: https://ty4stroke.com/threads/chaincase-adjustment-bolt.144917/#post-1322351
Thanks for the thread link.
Its been opened twice by dealer.
Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
BTW if you happen to have any pics of damage from chain id love to see them.
thx
Dan
Sorry, I did snap a couple of pics, but did not check them out after taking them. They came out terrible so I deleted them afterwards.
I remember Cannondale posting a link from the Viper section here at one of the winder threads, showing same damage which had occurred to a Viper from running the chain to loose. And yes the small diameter top gear does let the chain run closer to that nub. I had much the same amount of wear, about 1/4”.
STAIN
- Feb 29, 2004
- Vermont
- Vermont
both my Sidewinder and Viper were wearing on that nub. I will try to find the pictures i took a year or so ago
Luke Milanovich
- Sep 2, 2016
- Forest Lake
- 2012 Yamaha apex xtx
No ....the HH has the heel screw like dalton sorta but heel only.
the 60y is same as most all the STM supertips with 3 loading areas on each side.....and has more curvature in the Y then Ulmers YS.
Y similar to HH
YS similar to stock Winder weight.
Dalton in between and IMO best top speed weight.
Dan
I am working on my 2012 Apex XTX and I have the STM 60Y weights. I geared it down to 22/38 from 23/37, so what is your recommendation with my setup for Heel? Mid? Tip?
I have Ulmer springs (Primary Orange/Secondary Pink) and his G Helix.
- 10K
