blurred vision
I was woundering what would be better for an apex stage 3 supercharger at 18 to 20 pounds of bost. 9:1 or 10:1 pistons. Thanks in advanced for your help.
Ted Jannetty
blurred vision said:I was woundering what would be better for an apex stage 3 supercharger at 18 to 20 pounds of bost. 9:1 or 10:1 pistons. Thanks in advanced for your help.
Depends and what fuel your willing to run all the time.
The Higher compression will net better results as long as your willing to run the right fuel.
If you want to cheap out on the fuel you will have to go to lower compression and sacrafice some performance.
The fuel is the limiter the fuel is the limiter the fuel is the limiter!!!!!!!!!!!!!
blurred vision
How much would I lose for drag racing with the lower compression pistons, 9:1? I am going to run vp 116 octain.
Ted Jannetty
blurred vision said:How much would I lose for drag racing with the lower compression pistons, 9:1? I am going to run vp 116 octain.
If you going to run real fuel then leave the compression in it.
I run 22 psi boost on stock motor with Sunoco Maximal.
5.2 et, 1.2 60 ft, 130 mph in 660 ft.
blurred vision
How do you think It will work with 9:1 je pistions as the motor is already built? I thought it would be better with the higher compression, but the motor builder said the sled would make more power with the lower compression, as you would get more boost or more volume in the cylnders. I still think more compression is better. I'm hoping that it will really rock in 660 or a 1000 feet with 9:1?
Travis Moore
Re: 9:1
You could make as much power with 9 to 1 as 10 to 1, you'd just have to run more boost to do it, plus it'd be slightly 'laggier'.
Just like Ted said, the fuel is the limiter. You'd get the best performance out of 10 to 1 and a higher octane fuel then the 9 to 1 if you can run a good fuel. If you are only drag racing, I would just leave it alone as the lag is not much of a concern for a drag racing application (espically if you are using a 2 step, nitrous, etc).
T
blurred vision said:How do you think It will work with 9:1 je pistions as the motor is already built? I thought it would be better with the higher compression, but the motor builder said the sled would make more power with the lower compression, as you would get more boost or more volume in the cylnders. I still think more compression is better. I'm hoping that it will really rock in 660 or a 1000 feet with 9:1?
T
ripntear
- Jan 2, 2005
22lbs. off boost with 60 shot wet nitrous stock motor C-16. It is all about the fuel!
Boondockerguy
Just a little FYI.. the JE 9:1 pistons boondocker carries have anti-detonation grooves and double pin oilers....every little bit helps..
Also we saw a 20 hp difference on the dyno from stock compression vs. 9:1...
blurred vision
Hey guys. I'm still woundering if 9:1 will be good? Should I change to 10:1? I'm running c-16 fuel. I hope 9:1 is good for drag racing and racing on lakes. I'm running 20 pounds boost. Also, how much horsepower do you think i have?
srxguy
If you are running c-16 go with more compression....
Courtesy of DYNOTECH
http://www.dynotechresearch.com/techarticles.asp
Boondocker GT28RS on a Stock Yamaha Apex with 9:1 JE pistons
VP C16 provided all the octane necessary to tap out the Garrett GT28RS
12.5 psi boost (pump gas safe with the 9:1 pistons for reasonable lengths of time)
RPM.........Tq.......Hp......AFR.....CFM
10300 -- 119 -- 233 -- 11.7 -- 298
13.5 psi boost
RPM.........Tq......Hp.......AFR.....CFM
10900 -- 125 -- 259 -- 12.1 -- ???
17.5 psi boost
10400 -- 141 -- 279 -- 11.7 -- 353
20.5 psi boost
10100 -- 161 -- 310 -- 11.5 -- 386
26.0 psi boost
10200 -- 181 -- 352 -- 11.8 -- ???
13.5 psi boost
17.5 psi boost
20.5 psi boost
26.0 psi boost
Ted Jannetty
blurred vision said:Hey guys. I'm still woundering if 9:1 will be good? Should I change to 10:1? I'm running c-16 fuel. I hope 9:1 is good for drag racing and racing on lakes. I'm running 20 pounds boost. Also, how much horsepower do you think i have?
10:1 will make more power and run better off boost and have better response.
mulot30th
- Jul 7, 2007
- youtube.com
- 2023 thundercat
apex mountain crracing 174
apex blower 136 for asphalt racing
osp drag race sled (apex engine based)
on my all around rx1 blower (12psi) I have 9-1 je pistons and run pump fuel. 230hp
on my apex I run stock compression at 18psi and strait c16... 287hp
