justinator
- Mar 25, 2007
- Maine
- 2023 Arctic Cat Riot 9000
You dont have to be a serious racer to datalog your sled. Its for the person who wants to know what is going on and keep tabs on their sled to keep it at 100%. Ive given tons of examples in this thread as to why its a good idea and money well spent.Its not necessary but a valuable tool to have. No need for anyone to second guess anything especially those using 1 of the tuners who utilize the gap platform. This thread shows what can happen under certain circumstances, its not to scare anyone away from tuning their sled.......and that a certain companies knock protection isnt up to snuff apparently.Another thread with too much information for %99 of us..datalogging is for serious racing people..nobody needs to worry about the tunes under 280..Posts like these just gets everyone second guessing when there's no need for us %99er's
Turboflash
- Mar 18, 2019
- Southern MN
As my posts say, "for those interested". If anyone is not interested, then don't read the post/thread.
I feel that TY is a great site to visit to get great info from very very knowledgeable hard-core sledders who care and love the sport. If I can somehow contribute or assist in any way, that is my goal. I don't pretend to think I know more rhan most of you. This thread is just telling my experiences with the rebuilds I have done or am doing. If anyone doesn't think there's any value, then don't read it.
I'm hoping to contribute to TY in anyway I can.
max rolph
- Feb 10, 2021
- horse shoe valley
- 998 turbo
Just got mine back from total rebuild for stage 6, now its leaking oil out or around the mag cover while sitting.
Turboflash
- Mar 18, 2019
- Southern MN
Couple thoughts:
1. I would take it back to whoever did it; at least let them know.
2. There is "only" a thin paper composite gasket that seals that mag cover to the engine. I hope they got both the cover and the engine block very clean before they installed cover with new gasket.
3. There are 2 black screws at approx. 12 and 6 o'clock that require thread locker (per the manual). They are in open-ended holes that are exposed to engine oil. The rest of the screws are in blind holes so they won't leak. If they didn't use thread locker on those 2 bolts, they could leak oil.
4. The main oil suction tube is mounted to the cover. There is an o-ring that seals it into hole. I have seen those o-rings leaking before on a few sleds. I've seen the o-ring deformed by poor installation technique. I usually change o-ring to one slightly thicker to get more interference with a tighter seal. Might want to check it. Of course, you'll need to drain oil tank because the suction tube is lower that tank and oil will gush out.
Good luck.
Good luck.
max rolph
- Feb 10, 2021
- horse shoe valley
- 998 turbo
thanks, TD is very sorry that its leaking and were going to send mech 5 hours to fix but i ordered gaskets and am doing myself.... ive always smeared a thin layer of silicone or gasket shelack on gaskets no matter where they go... its only insurance of a good seal. the info on the two bolts to put sealant on is good to know , thanks
Turboflash
- Mar 18, 2019
- Southern MN
Check o-ring as well. Might want to get new one.
BTW - you're going to need a puller to get that cover off. The inside of the mag cover has the stationary side (coils) of the stator mounted to it. There is tremendous magnetic attraction between the rotating flywheel (mounted to crank) and the stator coils. Once you get all the screws out, the puller (looks like a special bolt) screws into the smaller hole in cover (there's a black plastic plug in this hole), and the end of puller pushes against flywheel to push cover outward and break magnetic force holding it on. If you don't have (or make) a puller, you'll have to insert something between cover and engine block, preferrably plastic or wood so you don't end up damaging the sealing surfaces. Have fun.
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
All spot on.. Been there on this.. I lost a stator and the mag side had to come off. Lots of fun getting it back on! I had some help from clutchmaster on my repair. Good detailed stuff Turboflash.. Lots of magnetic 4 letter words involved. Pretty sure we did it without a puller? / or it was a long bolt that matched the threads, BUT guessing a puller/bolt will make pulling and reinstalling a lot easier, with the magnetic force. I remember thinking a guy could fu&* his fingers up when reinstalling the mag side.. Once magnets grab she grabs!
max rolph
- Feb 10, 2021
- horse shoe valley
- 998 turbo
all done , what a bitch, the turbo mount has to be loosened and pryed out a 1/2inch so cover comes off, cleaned off the gasket with brass brush and scrapper, smeared gasket both sides with high heat silicone, place gasket over dowells on engine and then placed cover on... thank good i have strong hands.... when those magnets grip,,,, it fn yanks the cover on, 3rd time was a charm.... torqued all the screws and filled her up with ANOTHER jug of oil REDLINE synthetic 0w40 and fired up.... put paper towel under and left for a day... no drips!! BUT the pan gasket might have a slight seep.... i can see its shinny around edge. fck
max rolph
- Feb 10, 2021
- horse shoe valley
- 998 turbo
drilled a hole directly under the drain plug and then put a rear axle wheel rubber cap in hole (size i cant remember...1"?) wrks great no more mess.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
Too bad these guys aren't on this site sharing their knowledge.
max rolph
- Feb 10, 2021
- horse shoe valley
- 998 turbo
soo now i still have an oil leak from up high on engine, doesnt leeak if just idleing but if i bring revs up and do a few high revs on stand, i can look up from under sled with belly plates off... see front side of engines gets a sheet of oil coming dwn from higher up.... now it must be valve cover gasket im thinking.... can this be done while engine still in and is it difficult? pain in #*$&@? i have the gasket. i dont think the pan was leaking as first suspected... i think it was oil coming dwn then catching the edge of the gasket then flowing along it making it look wet. crossing my fingers here fck
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Facebook? Say no more!Too bad these guys aren't on this site sharing their knowledge.
rtx moose
- Jul 31, 2014
- WATERTOWN,MN
When was the last time you calibrated your torque wrench?soo now i still have an oil leak from up high on engine, doesnt leeak if just idleing but if i bring revs up and do a few high revs on stand, i can look up from under sled with belly plates off... see front side of engines gets a sheet of oil coming dwn from higher up.... now it must be valve cover gasket im thinking.... can this be done while engine still in and is it difficult? pain in #*$&@? i have the gasket. i dont think the pan was leaking as first suspected... i think it was oil coming dwn then catching the edge of the gasket then flowing along it making it look wet. crossing my fingers here fck
NYTurbo
- Sep 26, 2017
- Ottawa
- Sidewinder
Check the oil feed line for the turbo where it attaches to the block. Valve cover gasket can be done in sled if you move some #*$&@ out of the way
